Your electronic mail address---my mail,ok i got that one
The address of your POP3 server---don't know what to insert :(
Username and Pass---ok ;)
Address of your SMTP server---dont know
internet---got that one too :P
i don;t know what to insert to the pop3 and smtp address
Actually am trying to send a message to a friend and its says : "15: Peer connect failure (the host has refused the connection)."
HELP me...
Presumably you have a valid email address from some provider (usually an ISP).
Your Internet Service Provider (ISP) will also have two addresses which are required for you to connect to their servers to retrieve (Pop3) and send (SMTP) your email.
For example,
So, you need to find out from your ISP.
ok here is the prob...
i found pop3 and smtp and typed them and gives me the following error:
(in the email section i tried my hotmail and nothing)
[*] Connection established to XX.XXX.XXX.XXX(ip)
>> 0013 +OK ready
<< 0012 USER xxxxx(username)
>> 0034 +OK Password required for gutts.
<< 0014 PASS XXXXXXX
>> 0084 -ERR [AUTH] PAM authentication failed for user "xxxxx(username)": Authentication failure (7)
whats that ^
Can you give us more informations, like
- What's the name of your e-mail provider (Microsoft, Google, Yahoo, ...) ?
- What server names did you enter ?
ok here the deal:
my mail is hotmail.
my pop3 is : mail.otenet.gr
my smtp: mailgate.otenet.gr
in the internet e-mail address i put the hotmail mail...
as username and pas i inserted something random,it is ok?
Ok, just to get it right, a few more questions
You use hotmail for your e-mails.
As POP3 and SMTP you use the servers of your ISP otenet, right ?
I don't understand that configuration, maybe because I'm not using hotmail ;-)
Do you forward your email from hotmail to your ISP or vice versa ?
Have you an e-mail address like xxxx@otenet.gr ?
yeah i inserted pop3 and smtp of my isp otennet
*Do you forward your email from hotmail to your ISP or vice versa ?*
am not quit sure :S
*Have you an e-mail address like xxxx@otenet.gr ?*i dont think so....hmm am not helping much huh :P
[quote user="Werpoty"]
am not quit sure :S
If you don't know, i suggest No :-)
[quote]
AFAIK does Hotmail in the free version not offer an POP3 access.
You entered the Servers of your ISP, so you have to use the username and password
he provided you.
*You entered the Servers of your ISP, so you have to use the username and password
he provided you.* YAY it worked i got in (otenet.gt) and it means that when i send a mail to my friend it goes through otenet server to my friend and the opposite?
[quote user="Werpoty"]is there any way to exchange mail without passing through 3rd parties?
Yes, run your own mail server ;-)
or use mail services where you have access to the POP,IMAP and SMTP servers like Google or Yahoo.
To use that with hotmail, you have to pay for it.
i have another prob with the mail.I try to send a tesτ-mail and it says : *Faild to send SMTP message
Rejected XX.XXX.XX.XXX listed as spam source at http://www.spamhaus.org/* what should i do?
