Thanks for help in printing.
To print a picture imbeded in an email with text, I left double-click on the email line item in the upper right window of Pegasus v4.41. After that I right click 'Show pictures (HTML only)' and the gray rectangle replaced is replaced with the picture.
I then press Ctrl + Shift + p and get the 'Print' pop-up window with the 'Print Range' choice already made and the 'Pages... From...To' choices grayed out, so I have no ability to select a specific page range to print. If I then click OK on the 'Print' button, the printer prints out the email text along with the picture. A problem is, however, that one particular picture (800x515 pixels) is not resized to fit. A small amount of the right side of the picture is croped. Are these two actions (no 'Print Range' and 'cropping') standard when printing from Pegasus?
Another thing, after printing the email with picture and exiting Pegasus, I find a small box under where pegasus was, labeled 'Error'. The contents of the box is 'Runtime error 216 at 00002E00'. An OK button is provided to dismiss the box.
If I choose to 'open the email in a browser...', click 'File' in the browser and then 'Print...', one can select 'Page Range' and the picture gets resized, so there is no cropping. Exiting Pegasus and the browser reveals no "Error" box.
Sincerely,
Ben H. Tongue
Sincerely,
Ben H. Tongue
