Pegasus & Mercury/32 configuration
Can someone take a look at my configuartions.
I've been able to send mails in my ZenCart store to an email adress of my but it only sended the email, I didn't receive anything in my mail box.
So here's a quick view on how I tried to configure both.
Pegasus and Mercury/32 are both instaled on my local WAMPserver
Pegasus conf:
general settings: my internet email address: storekeeper@african_masks.com
Receiving(POP3): mail.african_masks.com
sending(SMTP): mail.african_masks.com
identities: <Default>
Pegasus MAil users: Admin
Mercury conf:
General: internet name for this system: african_masks.com
Local mailbox direct path: C:\WAMP\WWW\PMAIL\MAIL\~N
mail queue: C:\WAMP\WWW\MERCURY\QUEUE
Local domains: local host ro server internet name
african_masks african_masks
african_masks african_masks.com
MercuryE:
identify yourself as:
Name servers:
MercuryP:
General: IP interface to use: 84.198.71.118
Users defined for this system: Admin
If I send a mail message in Mercury/32 From postmaster@african_masks.com
to admin@african_masks.com I receive the message in Pegassus, so that already works.
If I however send a testmail from my ZenCart Store(Admin) from admin@african_masks.com
to an email address I get this message
Email Error:SMTP error: could not connect to SMTP host.
It actually did work 2days ago but I don't know what I'm doiing wrong s-ince then.
Now it takes bout 10 seconds to actually send the email in ZenCart compared to 2 seconds when it did work.
I have changed the mercury.ini file as well.
[quote user="lieven23"]
Pegasus conf:
Looks fairly normal, however neither the POP3 or SMTP host is valid. If you want to connect to the Mercury/32 host and you are on the same system you should be either "localhost" or "127.0.0.1". If you are one a different computer then use the IP address of the Mercury/32 host.
Mercury conf:looks reasonable but again the hosts are invalid but will work locally.
MercuryE:
Name servers:
If you are sending outside you should enter the IP addresses os the DNS host(s) you are using.
MercuryP:
This IP interface should be blank.
to admin@african_masks.com I receive the message in Pegasus, so that already works.
Pegasus Mail is sending via the mail spool directory and not MercuryS so this proves nothing when testing if the ZenCart will work.
If I however send a test mail from my ZenCart Store(Admin) from admin@african_masks.com
It actually did work 2days ago but I don't know what I'm doing wrong since then.
Are you running a MercuryS host? That is what the ZenCart will be using to send the mail. If ZenCart is running on the same system it should be using localhost or 127.0.0.1 as the SMTP host name.
I have changed the mercury.ini file as well.[/quote]
I have made the changes.
Now I can send email in Zen Admin but I don't receive it in my mailbox.
Have added MercuryS and have left everything blank.
Have added MercuryS and have left everything blank.You did not at least setup a log file so you could see if it was working? Turn on session logging and set thje session logging directory?
One more time, you need to be providing more information. Just telling us it that mail is not received is like telling your mechanic the car does not work and to fix it.
1. Does the MercuryS screen show it was received and processed normally? What do the MercuryS log show?
2. Does the core screen show the mail was processed? Was the message delivered locally or sent to the queue? What does the system log show?
3. If sent to a non-local address does MercuryE show it was processed? What does the MercuryE log show?
MercuryS screen:
Mercury/32 Transport System, POP3 Server Module v4.62,
Copyright (c) 1993-2008, David Harris, All Rights Reserved.
Portions of this program derived from the RSA Data Security, Inc. MD5
Message-Digest Algorithm, copyright 1991-92 RSA Data Security, Inc.
MercuryS log:
T 20080904 044421 48bf65f0 Connection from 127.0.0.1
T 20080904 044421 48bf65f0 EHLO african_masks.com
T 20080904 044421 48bf65f0 MAIL FROM:<admin@african_masks.com>
T 20080904 044421 48bf65f0 RCPT TO:<xxxxxx@telenet.be>
T 20080904 044421 48bf65f0 DATA
T 20080904 044422 48bf65f0 DATA - 24 lines, 943 bytes.
T 20080904 044422 48bf65f0 QUIT
T 20080904 044422 48bf65f0 Connection closed with 127.0.0.1, 1 sec. elapsed.
T 20080904 201822 48c0421f Connection from 127.0.0.1
T 20080904 201822 48c0421f EHLO african_masks.com
T 20080904 201822 48c0421f MAIL FROM:<admin@african_masks.com>
T 20080904 201822 48c0421f RCPT TO:<xxxxxx@telenet.be>
T 20080904 201822 48c0421f DATA
T 20080904 201822 48c0421f DATA - 24 lines, 943 bytes.
T 20080904 201822 48c0421f QUIT
T 20080904 201822 48c0421f Connection closed with 127.0.0.1, 0 sec. elapsed.
Core screen:
Mercury Mail Transport System v4.62,
Web: http://www.pmail.com, E-mail: support@pmail.gen.nz
Thu 04, 20:16:31: Mercury MTS Core processing thread running.
Thu 04, 20:18:32: Job MG000001: from admin@african_masks.com (local)
Created outgoing job with ID MO001310
xxxxx@telenet.be (non-local) -OK
Core log:
I 20080903 1520 MG000001 postmaster@african_masks.com admin 247
I 20080903 1557 MG000002 postmaster@african_masks.com admin 245
I 20080903 1604 MG000003 postmaster@african_masks.com admin 247
I 20080903 2347 MG000004 postmaster@african_masks.com admin 240
I 20080904 0056 MG000005 postmaster@african_masks.com admin 259
I 20080904 0429 MG000001 postmaster@african_masks.com admin 261
O 20080904 0444 MG000001 admin@african_masks.com xxxxx@telenet.be 1123
I 20080904 1325 MG000001 <> admin 1036
O 20080904 2018 MG000001 admin@african_masks.com xxxxx@telenet.be 1123
MercuryE log:
T 20080904 044432 48bf49d0 Begin processing job MO000002 from admin@african_masks.com
W 20080904 044432 48bf49d0 Temporary error 249 (temporary MX resolution error) resolving 'telenet.be'.
T 20080904 044432 48bf49d0 Job MO000002 processing complete.
T 20080904 132517 48bfc58d Begin processing job MO000002 from admin@african_masks.com
W 20080904 132517 48bfc58d Temporary error 249 (temporary MX resolution error) resolving 'telenet.be'.
T 20080904 132517 48bfc58d Job MO000002 processing complete.
T 20080904 135525 48bfc58e Begin processing job MO000002 from admin@african_masks.com
W 20080904 135525 48bfc58e Temporary error 249 (temporary MX resolution error) resolving 'telenet.be'.
T 20080904 135525 48bfc58e Job MO000002 processing complete.
T 20080904 142533 48bfc58f Begin processing job MO000002 from admin@african_masks.com
W 20080904 142533 48bfc58f Temporary error 249 (temporary MX resolution error) resolving 'telenet.be'.
T 20080904 142533 48bfc58f Job MO000002 processing complete.
T 20080904 145541 48bfc590 Begin processing job MO000002 from admin@african_masks.com
W 20080904 145541 48bfc590 Temporary error 249 (temporary MX resolution error) resolving 'telenet.be'.
T 20080904 145541 48bfc590 Job MO000002 processing complete.
T 20080904 153006 48bfe2cc Begin processing job MO000002 from admin@african_masks.com
W 20080904 153006 48bfe2cc Temporary error 249 (temporary MX resolution error) resolving 'telenet.be'.
T 20080904 153006 48bfe2cc Job MO000002 processing complete.
T 20080904 201647 48c025ff Begin processing job MO000002 from admin@african_masks.com
W 20080904 201647 48c025ff Temporary error 249 (temporary MX resolution error) resolving 'telenet.be'.
T 20080904 201647 48c025ff Job MO000002 processing complete.
T 20080904 201839 48c02600 Begin processing job MO001310 from admin@african_masks.com
W 20080904 201839 48c02600 Temporary error 249 (temporary MX resolution error) resolving 'telenet.be'.
T 20080904 201839 48c02600 Job MO001310 processing complete.
MercuryE SMTP client:
MercuryS screen:
MercuryS log:T 20080904 044421 48bf65f0 Connection from 127.0.0.1
T 20080904 044421 48bf65f0 RCPT TO:<lieven.van.meulder@telenet.be>
T 20080904 201822 48c0421f RCPT TO:<lieven.van.meulder@telenet.be>
MercuryS received the mail and created a MG000001.QCF/QDF file pair in the queue.
Core screen:
To: lieven.van.meulder@telenet.be (non-local) -OK
Mercury core processed the message and created a non-local message in the queue for sending consisting of a pair MOO001310.QCF/QDF files.
Core log:
O 20080904 0444 MG000001 admin@african_masks.com lieven.van.meulder@telenet.be 1123
O 20080904 2018 MG000001 admin@african_masks.com lieven.van.meulder@telenet.be 1123
MercuryE log:
MercuryE failed to resolve the domain telenet.be. It's a valid domain, do you have the IP addresses of yuor DNS hosts in the MercuryE setup?
Answer Section:
telenet.be, MX, 100, smtp-telenet.telenet-ops.be
telenet.be, MX, 10, smtp-telenet-imp.telenet-ops.be
T 20080904 132517 48bfc58d Begin processing job MO000002 from admin@african_masks.comIt finally gave up since it could not resolve the MX host for any of the jobs.
MercuryE SMTP client:Mercury/32 Transport System, Full SMTP Client Module v4.62,
This product includes software developed by the University
of California, Berkeley and its contributors. Portions of this
program are copyright (c) 1999-2001, MurkWorks Inc,
http://www.murkworks.com
Current name service information:
Hosts file : C:\WINDOWS\System32\drivers\etc\hosts
Domain :
Nameserver 1 : 84.198.71.115
That's not a DNS host, that appears to be the IP address of your system. I would expect you to be using one of these or maybe both.
Additional Records Section:
ns.telenet-ops.be, A, 195.130.132.17
ns2.telenet-ops.be, A, 213.224.126.242
In addition the structure here does not look right either, mine looks like this http://tstephenson.com/Pegasus/mercurye.jpg
20:16:47: processing job MO000002
20:18:39: processing job MO001310
In MercuryE DNS Host I put this : 195.130.132.17
Don't know what to do with this.
Answer Section:
I've also tried to put these in DNS host
I copied the values (numbers) of your mercuryE configuratin screen
I copied the values (numbers) of your mercuryE configuratin screenYour email address and IP address is in the domain telenet.de. The Domain Name Severs for this domain are
DNS host: ns2.telenet-ops.be, A, 213.224.126.242 Why doesn't he want to accept this?
20080905 001752 48c0260f Begin processing job MO000002 from admin@african_masks.com
W 20080905 001752 48c0260f Temporary error 249 (temporary MX resolution error) resolving 'telenet.be'.
T 20080905 001752 48c0260f Job MO000002 processing complete.
T 20080905 003237 48c061f4 Begin processing job MO001310 from admin@african_masks.com
W 20080905 003237 48c061f4 Temporary error 249 (temporary MX resolution error) resolving 'telenet.be'.
T 20080905 003237 48c061f4 Job MO001310 processing complete.
T 20080905 004804 48c061f5 Begin processing job MO000002 from admin@african_masks.com
W 20080905 004804 48c061f5 Temporary error 249 (temporary MX resolution error) resolving 'telenet.be'.
T 20080905 004804 48c061f5 Job MO000002 processing complete.
T 20080905 010244 48c061f6 Begin processing job MO001310 from admin@african_masks.com
W 20080905 010244 48c061f6 Temporary error 249 (temporary MX resolution error) resolving 'telenet.be'.
T 20080905 010244 48c061f6 Job MO001310 processing complete.
T 20080905 010852 48c061f7 Begin processing job MO000003 from admin@african_masks.com
W 20080905 010853 48c061f7 Error connecting to primary server '195.130.137.65'.
W 20080905 010936 48c061f7 Error connecting to alternate server '195.130.132.41'.
E 20080905 010936 48c061f7 Processing of job MO000003 incomplete or failed.
T 20080905 010936 48c061f7 Job MO000003 processing complete.
T 20080905 011148 48c061f8 Begin processing job MO000005 from admin@african_masks.com
W 20080905 011149 48c061f8 Error connecting to primary server '195.130.137.65'.
W 20080905 011233 48c061f8 Error connecting to alternate server '195.130.132.52'.
E 20080905 011233 48c061f8 Processing of job MO000005 incomplete or failed.
T 20080905 011233 48c061f8 Job MO000005 processing complete.
T 20080905 011812 48c061f9 Begin processing job MO000002 from admin@african_masks.com
W 20080905 011854 48c061f9 Error connecting to primary server '195.130.132.52'.
W 20080905 011855 48c061f9 Error connecting to alternate server '195.130.132.49'.
E 20080905 011855 48c061f9 Processing of job MO000002 incomplete or failed.
T 20080905 011855 48c061f9 Job MO000002 processing complete.
T 20080905 012140 48c061fa Begin processing job MO000009 from admin@african_masks.com
W 20080905 012141 48c061fa Error connecting to primary server '195.130.137.65'.
W 20080905 012224 48c061fa Error connecting to alternate server '195.130.132.41'.
E 20080905 012224 48c061fa Processing of job MO000009 incomplete or failed.
T 20080905 012224 48c061fa Job MO000009 processing complete.
T 20080905 013220 48c061fb Begin processing job MO00000B from admin@african_masks.com
T 20080905 013252 48c061fc Begin processing job MO001310 from admin@african_masks.com
T 20080905 013428 48c061fd Begin processing job MO00000D from admin@african_masks.com
W 20080905 013559 48c061fb Temporary error 249 (temporary MX resolution error) resolving 'telenet.be'.
T 20080905 013559 48c061fb Job MO00000B processing complete.
W 20080905 013631 48c061fc Temporary error 249 (temporary MX resolution error) resolving 'telenet.be'.
T 20080905 013631 48c061fc Job MO001310 processing complete.
W 20080905 013640 48c061fd Temporary error 249 (temporary MX resolution error) resolving 'telenet.be'.
T 20080905 013640 48c061fd Job MO00000D processing complete.
T 20080905 013948 48c061fe Begin processing job MO000003 from admin@african_masks.com
W 20080905 013949 48c061fe Error connecting to primary server '195.130.132.49'.
T 20080905 014010 48c061ff Begin processing job MO00000F from admin@african_masks.com
W 20080905 014011 48c061ff Error connecting to primary server '195.130.137.65'.
W 20080905 014032 48c061fe Error connecting to alternate server '195.130.132.52'.
E 20080905 014032 48c061fe Processing of job MO000003 incomplete or failed.
T 20080905 014032 48c061fe Job MO000003 processing complete.
W 20080905 014054 48c061ff Error connecting to alternate server '195.130.132.52'.
E 20080905 014054 48c061ff Processing of job MO00000F incomplete or failed.
T 20080905 014054 48c061ff Job MO00000F processing complete.
T 20080905 014233 48c06200 Begin processing job MO000005 from admin@african_masks.com
W 20080905 014234 48c06200 Error connecting to primary server '195.130.132.34'.
W 20080905 014317 48c06200 Error connecting to alternate server '195.130.132.52'.
E 20080905 014317 48c06200 Processing of job MO000005 incomplete or failed.
T 20080905 014317 48c06200 Job MO000005 processing complete.
T 20080905 015227 48c06201 Begin processing job MO000009 from admin@african_masks.com
W 20080905 015228 48c06201 Error connecting to primary server '195.130.132.34'.
W 20080905 015311 48c06201 Error connecting to alternate server '195.130.132.41'.
E 20080905 015311 48c06201 Processing of job MO000009 incomplete or failed.
T 20080905 015311 48c06201 Job MO000009 processing complete.
T 20080905 020601 48c06202 Begin processing job MO00000B from admin@african_masks.com
W 20080905 020602 48c06202 Error connecting to primary server '195.130.137.65'.
T 20080905 020634 48c06203 Begin processing job MO001310 from admin@african_masks.com
T 20080905 020645 48c06204 Begin processing job MO00000D from admin@african_masks.com
W 20080905 020645 48c06202 Error connecting to alternate server '195.130.132.41'.
E 20080905 020645 48c06202 Processing of job MO00000B incomplete or failed.
T 20080905 020645 48c06202 Job MO00000B processing complete.
W 20080905 020646 48c06204 Error connecting to primary server '195.130.132.34'.
W 20080905 020715 48c06203 Error connecting to primary server '195.130.132.49'.
W 20080905 020729 48c06204 Error connecting to alternate server '195.130.132.52'.
E 20080905 020729 48c06204 Processing of job MO00000D incomplete or failed.
T 20080905 020729 48c06204 Job MO00000D processing complete.
W 20080905 020758 48c06203 Error connecting to alternate server '195.130.132.41'.
E 20080905 020758 48c06203 Processing of job MO001310 incomplete or failed.
T 20080905 020758 48c06203 Job MO001310 processing complete.
T 20080905 021036 48c06205 Begin processing job MO000003 from admin@african_masks.com
T 20080905 021058 48c06206 Begin processing job MO00000F from admin@african_masks.com
W 20080905 021059 48c06206 Error connecting to primary server '195.130.137.65'.
W 20080905 021119 48c06205 Error connecting to primary server '195.130.132.52'.
W 20080905 021120 48c06205 Error connecting to alternate server '195.130.132.34'.
E 20080905 021120 48c06205 Processing of job MO000003 incomplete or failed.
T 20080905 021120 48c06205 Job MO000003 processing complete.
W 20080905 021142 48c06206 Error connecting to alternate server '195.130.132.41'.
E 20080905 021142 48c06206 Processing of job MO00000F incomplete or failed.
T 20080905 021142 48c06206 Job MO00000F processing complete.
T 20080905 021321 48c06207 Begin processing job MO000005 from admin@african_masks.com
W 20080905 021404 48c06207 Error connecting to primary server '195.130.132.41'.
W 20080905 021405 48c06207 Error connecting to alternate server '195.130.132.49'.
E 20080905 021405 48c06207 Processing of job MO000005 incomplete or failed.
T 20080905 021405 48c06207 Job MO000005 processing complete.
T 20080905 022315 48c06208 Begin processing job MO000009 from admin@african_masks.com
W 20080905 022358 48c06208 Error connecting to primary server '195.130.132.52'.
W 20080905 022359 48c06208 Error connecting to alternate server '195.130.132.34'.
E 20080905 022359 48c06208 Processing of job MO000009 incomplete or failed.
T 20080905 022359 48c06208 Job MO000009 processing complete.
T 20080905 023650 48c06209 Begin processing job MO00000B from admin@african_masks.com
W 20080905 023733 48c06209 Error connecting to primary server '195.130.132.41'.
T 20080905 023734 48c0620a Begin processing job MO00000D from admin@african_masks.com
W 20080905 023734 48c06209 Error connecting to alternate server '195.130.137.65'.
E 20080905 023734 48c06209 Processing of job MO00000B incomplete or failed.
T 20080905 023734 48c06209 Job MO00000B processing complete.
T 20080905 023807 48c0620b Begin processing job MO001310 from admin@african_masks.com
W 20080905 023808 48c0620b Error connecting to primary server '195.130.132.34'.
W 20080905 023817 48c0620a Error connecting to primary server '195.130.132.41'.
W 20080905 023818 48c0620a Error connecting to alternate server '195.130.137.65'.
E 20080905 023818 48c0620a Processing of job MO00000D incomplete or failed.
T 20080905 023818 48c0620a Job MO00000D processing complete.
W 20080905 023851 48c0620b Error connecting to alternate server '195.130.132.41'.
E 20080905 023851 48c0620b Processing of job MO001310 incomplete or failed.
T 20080905 023851 48c0620b Job MO001310 processing complete.
T 20080905 024125 48c0620c Begin processing job MO000003 from admin@african_masks.com
T 20080905 024147 48c0620d Begin processing job MO00000F from admin@african_masks.com
W 20080905 024208 48c0620c Error connecting to primary server '195.130.132.41'.
W 20080905 024209 48c0620c Error connecting to alternate server '195.130.132.34'.
E 20080905 024209 48c0620c Processing of job MO000003 incomplete or failed.
T 20080905 024209 48c0620c Job MO000003 processing complete.
W 20080905 024230 48c0620d Error connecting to primary server '195.130.132.41'.
W 20080905 024231 48c0620d Error connecting to alternate server '195.130.132.49'.
E 20080905 024231 48c0620d Processing of job MO00000F incomplete or failed.
T 20080905 024231 48c0620d Job MO00000F processing complete.
T 20080905 024410 48c0620e Begin processing job MO000005 from admin@african_masks.com
W 20080905 024453 48c0620e Error connecting to primary server '195.130.132.52'.
W 20080905 024454 48c0620e Error connecting to alternate server '195.130.137.65'.
E 20080905 024454 48c0620e Processing of job MO000005 incomplete or failed.
T 20080905 024454 48c0620e Job MO000005 processing complete.
T 20080905 025404 48c0620f Begin processing job MO000009 from admin@african_masks.com
W 20080905 025447 48c0620f Error connecting to primary server '195.130.132.52'.
W 20080905 025448 48c0620f Error connecting to alternate server '195.130.132.34'.
E 20080905 025448 48c0620f Processing of job MO000009 incomplete or failed.
T 20080905 025448 48c0620f Job MO000009 processing complete.
T 20080905 040617 48c0940e Begin processing job MO000003 from admin@african_masks.com
T 20080905 040617 48c0940f Begin processing job MO000005 from admin@african_masks.com
T 20080905 040617 48c09410 Begin processing job MO000009 from admin@african_masks.com
T 20080905 040617 48c09411 Begin processing job MO00000B from admin@african_masks.com
T 20080905 040617 48c09412 Begin processing job MO00000D from admin@african_masks.com
T 20080905 040617 48c09413 Begin processing job MO00000F from admin@african_masks.com
T 20080905 040617 48c09414 Begin processing job MO001310 from admin@african_masks.com
W 20080905 040619 48c09414 Error connecting to primary server '195.130.137.65'.
W 20080905 040700 48c09410 Error connecting to primary server '195.130.132.41'.
W 20080905 040701 48c0940e Error connecting to primary server '195.130.132.41'.
W 20080905 040701 48c09412 Error connecting to primary server '195.130.132.41'.
W 20080905 040701 48c09413 Error connecting to primary server '195.130.132.52'.
W 20080905 040701 48c09411 Error connecting to primary server '195.130.132.41'.
W 20080905 040701 48c0940f Error connecting to primary server '195.130.132.41'.
W 20080905 040701 48c09410 Error connecting to alternate server '195.130.137.65'.
E 20080905 040701 48c09410 Processing of job MO000009 incomplete or failed.
T 20080905 040701 48c09410 Job MO000009 processing complete.
W 20080905 040702 48c0940e Error connecting to alternate server '195.130.132.49'.
E 20080905 040702 48c0940e Processing of job MO000003 incomplete or failed.
T 20080905 040702 48c0940e Job MO000003 processing complete.
W 20080905 040702 48c09413 Error connecting to alternate server '195.130.137.65'.
E 20080905 040702 48c09413 Processing of job MO00000F incomplete or failed.
W 20080905 040702 48c09412 Error connecting to alternate server '195.130.137.65'.
T 20080905 040702 48c09413 Job MO00000F processing complete.
E 20080905 040702 48c09412 Processing of job MO00000D incomplete or failed.
T 20080905 040702 48c09412 Job MO00000D processing complete.
W 20080905 040702 48c09411 Error connecting to alternate server '195.130.132.34'.
E 20080905 040702 48c09411 Processing of job MO00000B incomplete or failed.
W 20080905 040702 48c0940f Error connecting to alternate server '195.130.137.65'.
E 20080905 040702 48c0940f Processing of job MO000005 incomplete or failed.
T 20080905 040702 48c09411 Job MO00000B processing complete.
T 20080905 040702 48c0940f Job MO000005 processing complete.
W 20080905 040702 48c09414 Error connecting to alternate server '195.130.132.41'.
E 20080905 040702 48c09414 Processing of job MO001310 incomplete or failed.
T 20080905 040702 48c09414 Job MO001310 processing complete.
T 20080905 040946 48c09415 Begin processing job MO000002 from admin@african_masks.com
T 20080905 042002 48c09416 Begin processing job MO000004 from admin@african_masks.com
T 20080905 042042 48c0976f Begin processing job MO000002 from admin@african_masks.com
T 20080905 042042 48c09770 Begin processing job MO000004 from admin@african_masks.com
T 20080905 042137 48c09771 Begin processing job MO001312 from admin@african_masks.com
G 20080905 042458 0 Poll forced from interface
T 20080905 042553 48c098a6 Begin processing job MO000002 from admin@african_masks.com
T 20080905 042553 48c098a7 Begin processing job MO000004 from admin@african_masks.com
T 20080905 042553 48c098a8 Begin processing job MO001312 from admin@african_masks.com
T 20080905 042626 48c098a9 Begin processing job MO001311 from admin@african_masks.com
I have called Telenet, my ISP , and they told me I need a business solution for setup a mailserver.
So it is normal I don't receive my emails.[:)]
I have called Telenet, my ISP , and they told me I need a business solution for setup a mailserver.Use Configuration | Protocols to setup Mercury/32 to use MercuryC instead of MercuryE and it will be operating just like a e-mail client using the telenet.be SMTP host as a relay host to send the mail. You enter the host name of the smtp host that you would use for sending from any e-mail client. See http://tstephenson.com/pegasus/mercuryc.jpg
[quote user="lieven23"] I have called Telenet, my ISP , and they told me I need a business solution for setup a mailserver.[/quote]
This is a standard answer from many ISPs - sure you can have a mailserver for outgoing emails - just as Thomas has described.
My ISP told me to use "uit.telenet.be" as the SMTP host.
but in the MercuryC logs I see this
T 20080907 021535 754 Begin processing job MO000013 from admin@african_masks.com
W 20080907 021535 754 450 4.1.8 <admin@african_masks.com>: Sender address rejected: Domain not found
also
The attached message has failed delivery and has been referredI'm not able to find a domain registered as african_masks.com. One good reason for this is that although domain names may contain hyphens they can't contain underscores. Please try using a proper sender address.
hi Rolf
I've changed the domain name with nomore underscores but hyphens and all its related files but with no result.
My site is still on a local server. Do I have to have a registred domain name for beiing able to send email from admin@african-masks.com to an axtrenal email account of me??
I thought that was the advantage of working local, you didn't have to be registred yet.
Thx for your help
