Setting up mercury and pegasus on localhost...
thanx very much...
success already, cannot be without your help...
<p>thanx very much...</p><p>success already, cannot be without your help... </p>
hi...i'm a final year student in malaysia, trying to configure a connection using pegasus and mercury on my own computer.
i've downloaded both files...and cannot find step by step way to configure both.i've been trying to do this for almost a week, with no success...
i hope anyone can help me....
i've downloaded mercury 4.62 and pegasus 4.41..is there any other software i need..?do i need to run apache server..?
from what i did, i have error sending and recieving emails..with error such "15:peer connect failure....."
what module should i install for mercury..please help me...i'm lost...
 thank you very much in advanced...may God bless u...
<p>hi...i'm a final year student in malaysia, trying to configure a connection using pegasus and mercury on my own computer. i've downloaded both files...and cannot find step by step way to configure both.i've been trying to do this for almost a week, with no success... i hope anyone can help me.... i've downloaded mercury 4.62 and pegasus 4.41..is there any other software i need..?do i need to run apache server..?</p><p>from what i did, i have error sending and recieving emails..with error such "15:peer connect failure....."</p><p>what module should i install for mercury..please help me...i'm lost...</p><p> thank you very much in advanced...may God bless u... </p>
> server..?
FWIW, the ISP may be doing port 25 blocking and as such yuo must use MercuryC for sending the mail using the ISPs SMTP host as a relay host.
1.  Install WinPmail in the multiuser mode on the "server".  Use c:\pmail
    for the program; c:\pmail\mail for the mail directories.
2.  Run PCONFIG.exe from the WinPMail program directory and change the HOME and
    NEW mail directory specification to the \\server\vol\pmail\mail\~8
    format.
3.  Go to the remote workstations and install a shortcut to the common
    program.
Ok, now you have the basic mail system setup.  You can send mail to each other using Pegasus Mail.
4.  Install Mercury/32 on this same server pointing to the Pegasus Mail
    directory structure.  Use MercuryD, MercuryS, MercuryC at least. Use
    \\server\vol\mercury\queue for the mail spool directory.
5.  Point MercuryD at all of your POP3 mailboxes to download the mail to
    your Pegasus Mail user directories.
You now can send and receive Internet mail via Pegasus Mail.  The mail is delivered to the Pegasus Mail directories automatically.  You send mail simply but putting the output files into the Mercury/32 mail spool directory.  This is accomplished automatically with a Pegasus Mail User Defined Gateway.
6.  If you want to maintain other POP3/IMAP4 clients, point the client at
    the at your Mercury/32 host as a POP3 and SMTP host using the Pegasus
    Mail username and password to pickup the mail.
<p>> hi...i'm a final year student in malaysia, trying to configure a > connection using pegasus and mercury on my own computer. i've > downloaded both files...and cannot find step by step way to configure > both.i've been trying to do this for almost a week, with no success... > i hope anyone can help me.... i've downloaded mercury 4.62 and pegasus > 4.41..is there any other software i need..?do i need to run apache > server..? > > from what i did, i have error sending and recieving emails..with error such "15:peer connect failure....."</p><p>FWIW, the ISP may be doing port 25 blocking and as such yuo must use MercuryC for sending the mail using the ISPs SMTP host as a relay host. </p><p>> > what module should i install for mercury..please help me...i'm lost... > >  thank you very much in advanced...may God bless u... 1.  Install WinPmail in the multiuser mode on the "server".  Use c:\pmail     for the program; c:\pmail\mail for the mail directories. 2.  Run PCONFIG.exe from the WinPMail program directory and change the HOME and     NEW mail directory specification to the \\server\vol\pmail\mail\~8     format. 3.  Go to the remote workstations and install a shortcut to the common     program. Ok, now you have the basic mail system setup.  You can send mail to each other using Pegasus Mail.   4.  Install Mercury/32 on this same server pointing to the Pegasus Mail     directory structure.  Use MercuryD, MercuryS, MercuryC at least. Use     \\server\vol\mercury\queue for the mail spool directory. 5.  Point MercuryD at all of your POP3 mailboxes to download the mail to     your Pegasus Mail user directories. You now can send and receive Internet mail via Pegasus Mail.  The mail is delivered to the Pegasus Mail directories automatically.  You send mail simply but putting the output files into the Mercury/32 mail spool directory.  This is accomplished automatically with a Pegasus Mail User Defined Gateway.   6.  If you want to maintain other POP3/IMAP4 clients, point the client at     the at your Mercury/32 host as a POP3 and SMTP host using the Pegasus     Mail username and password to pickup the mail. </p>
i'm sorry, but i cannot follow your instructions...
what i mean is..when i want to configure both pegasus and mercury to be working in localhost only..no need internet connection.
what is the right answer to put in these form...
installingnew copy
installation option
email address
pop server
smtp
and when installing mercury/32...these is the form..
where to install?
integration with pagsus
mailbox directory
protocol to choose
smtp client module
basic configurations
queue location
relay
ok..these is the form that i dont know what to fill in...sorry for your trouble..and thanx a lot for helping
<p>i'm sorry, but i cannot follow your instructions...</p><p>what i mean is..when i want to configure both pegasus and mercury to be working in localhost only..no need internet connection.</p><p>what is the right answer to put in these form...</p><p><img src="%3Ca%20href=%22http://www.friendster.com/photos/6482373/1/528470453%22%3E%3Cimg%20src=%22http://photos.friendster.com/photos/37/32/6482373/1_528470453l.jpg%22%20border=%220%22/%3E%3C/a%3E" title="installingnew copy" alt="installingnew copy" mce_src="<a mce_thref="http://www.friendster.com/photos/6482373/1/528470453"><img mce_tsrc="http://photos.friendster.com/photos/37/32/6482373/1_528470453l.jpg" border="0"/></a>"> </p><p><img src="%3Ca%20href=%22http://www.friendster.com/photos/6482373/1/251024948%22%3E%3Cimg%20border=%220%22%20src=%22http://photos.friendster.com/photos/37/32/6482373/1_251024948l.jpg%22/%3E%3C/a%3E" title="installation option" alt="installation option" mce_src="<a mce_thref="http://www.friendster.com/photos/6482373/1/251024948"><img border="0" mce_tsrc="http://photos.friendster.com/photos/37/32/6482373/1_251024948l.jpg"/></a>"></p><p><img src="%3Ca%20href=%22http://www.friendster.com/photos/6482373/1/429902774%22%3E%3Cimg%20border=%220%22%20src=%22http://photos.friendster.com/photos/37/32/6482373/1_429902774l.jpg%22/%3E%3C/a%3E" title="email address" alt="email address" mce_src="<a mce_thref="http://www.friendster.com/photos/6482373/1/429902774"><img border="0" mce_tsrc="http://photos.friendster.com/photos/37/32/6482373/1_429902774l.jpg"/></a>"> </p><p><img src="%3Ca%20href=%22http://www.friendster.com/photos/6482373/1/400190833%22%3E%3Cimg%20border=%220%22%20src=%22http://photos.friendster.com/photos/37/32/6482373/1_400190833l.jpg%22/%3E%3C/a%3E" title="pop server" alt="pop server" mce_src="<a mce_thref="http://www.friendster.com/photos/6482373/1/400190833"><img border="0" mce_tsrc="http://photos.friendster.com/photos/37/32/6482373/1_400190833l.jpg"/></a>"></p><p><img src="%3Ca%20href=%22http://www.friendster.com/photos/6482373/1/248926852%22%3E%3Cimg%20border=%220%22%20src=%22http://photos.friendster.com/photos/37/32/6482373/1_248926852l.jpg%22/%3E%3C/a%3E" title="username and password" alt="username and password" mce_src="<a mce_thref="http://www.friendster.com/photos/6482373/1/248926852"><img border="0" mce_tsrc="http://photos.friendster.com/photos/37/32/6482373/1_248926852l.jpg"/></a>"></p><p><img src="%3Ca%20href=%22http://www.friendster.com/photos/6482373/1/668795989%22%3E%3Cimg%20border=%220%22%20src=%22http://photos.friendster.com/photos/37/32/6482373/1_668795989l.jpg%22/%3E%3C/a%3E" title="smtp" alt="smtp" mce_src="<a mce_thref="http://www.friendster.com/photos/6482373/1/668795989"><img border="0" mce_tsrc="http://photos.friendster.com/photos/37/32/6482373/1_668795989l.jpg"/></a>"></p><p>and when installing mercury/32...these is the form..</p><p><img src="%3Ca%20href=%22http://www.friendster.com/photos/6482373/1/402449174%22%3E%3Cimg%20border=%220%22%20src=%22http://photos.friendster.com/photos/37/32/6482373/1_402449174l.jpg%22/%3E%3C/a%3E" title="where to install?" alt="where to install?" mce_src="<a mce_thref="http://www.friendster.com/photos/6482373/1/402449174"><img border="0" mce_tsrc="http://photos.friendster.com/photos/37/32/6482373/1_402449174l.jpg"/></a>"></p><p><img src="%3Ca%20href=%22http://www.friendster.com/photos/6482373/1/835101632%22%3E%3Cimg%20border=%220%22%20src=%22http://photos.friendster.com/photos/37/32/6482373/1_835101632l.jpg%22/%3E%3C/a%3E" title="integration with pagsus" alt="integration with pagsus" mce_src="<a mce_thref="http://www.friendster.com/photos/6482373/1/835101632"><img border="0" mce_tsrc="http://photos.friendster.com/photos/37/32/6482373/1_835101632l.jpg"/></a>"></p><p><img src="%3Ca%20href=%22http://www.friendster.com/photos/6482373/1/712518664%22%3E%3Cimg%20border=%220%22%20src=%22http://photos.friendster.com/photos/37/32/6482373/1_712518664l.jpg%22/%3E%3C/a%3E" title="mailbox directory" alt="mailbox directory" mce_src="<a mce_thref="http://www.friendster.com/photos/6482373/1/712518664"><img border="0" mce_tsrc="http://photos.friendster.com/photos/37/32/6482373/1_712518664l.jpg"/></a>"></p><p><img src="%3Ca%20href=%22http://www.friendster.com/photos/6482373/1/380156415%22%3E%3Cimg%20border=%220%22%20src=%22http://photos.friendster.com/photos/37/32/6482373/1_380156415l.jpg%22/%3E%3C/a%3E" title="protocol to choose" alt="protocol to choose" mce_src="<a mce_thref="http://www.friendster.com/photos/6482373/1/380156415"><img border="0" mce_tsrc="http://photos.friendster.com/photos/37/32/6482373/1_380156415l.jpg"/></a>"></p><p><img src="%3Ca%20href=%22http://www.friendster.com/photos/6482373/1/450847076%22%3E%3Cimg%20border=%220%22%20src=%22http://photos.friendster.com/photos/37/32/6482373/1_450847076l.jpg%22/%3E%3C/a%3E" title="smtp client module" alt="smtp client module" mce_src="<a mce_thref="http://www.friendster.com/photos/6482373/1/450847076"><img border="0" mce_tsrc="http://photos.friendster.com/photos/37/32/6482373/1_450847076l.jpg"/></a>"></p><p><img src="%3Ca%20href=%22http://www.friendster.com/photos/6482373/1/493760581%22%3E%3Cimg%20border=%220%22%20src=%22http://photos.friendster.com/photos/37/32/6482373/1_493760581l.jpg%22/%3E%3C/a%3E" title="basic configurations" alt="basic configurations" mce_src="<a mce_thref="http://www.friendster.com/photos/6482373/1/493760581"><img border="0" mce_tsrc="http://photos.friendster.com/photos/37/32/6482373/1_493760581l.jpg"/></a>"></p><p><img src="%3Ca%20href=%22http://www.friendster.com/photos/6482373/1/561833417%22%3E%3Cimg%20border=%220%22%20src=%22http://photos.friendster.com/photos/37/32/6482373/1_561833417l.jpg%22/%3E%3C/a%3E" title="queue location" alt="queue location" mce_src="<a mce_thref="http://www.friendster.com/photos/6482373/1/561833417"><img border="0" mce_tsrc="http://photos.friendster.com/photos/37/32/6482373/1_561833417l.jpg"/></a>"></p><p><img src="%3Ca%20href=%22http://www.friendster.com/photos/6482373/1/642418071%22%3E%3Cimg%20border=%220%22%20src=%22http://photos.friendster.com/photos/37/32/6482373/1_642418071l.jpg%22/%3E%3C/a%3E" title="relay" alt="relay" mce_src="<a mce_thref="http://www.friendster.com/photos/6482373/1/642418071"><img border="0" mce_tsrc="http://photos.friendster.com/photos/37/32/6482373/1_642418071l.jpg"/></a>"></p><p> </p><p>ok..these is the form that i dont know what to fill in...sorry for your trouble..and thanx a lot for helping </p>
A lot of these questions were answered in my first post, are you sure you read it?
If you do not need the internet connection parts do not use them.  The process is simple, you install Pegasus Mail to c:\pmail as Multiuser using c:\pmail\mail as the mailbox location.
You install Mercury/32 to c:\mercury using the defaults and then point it at the Pegasus Mail program (c:\pmail\programs) and mailbox (c:\pmail\mail) locations during the install.
> installingnew copy
Pegasus Mail is installed to c:\pmail
> installation option
Multiuser and the mail directory is c:\pmail\mail
> email address
It's the local username and the domain you use when creating the users in Configuration | Manage local users.  For example, if you use mydomain.com in the Configuration | Mercury core | Domains and create a user called Admin then the e-mail address is admin@mydomain.com.  The Tools | Internet options | General entries are not required in a integrated setup.
> pop server
If on the same system as Mercury then use 127.0.0.1.  The Tools | Internet options | (Receiving)POP3 is not required on an integrated setup.
The username is the name is the user you created in Mercury/32.  The password is the password you gave the user.
> smtp
If on the same system as Mercury then use 127.0.0.1.  The Tools | Internet options | (Sending) SMTP is not required on an integrated setup.
> where to install?
c:\mercury
> mailbox directory
c:\pmail\mail\~n
> protocol to choose
> smtp client module
MercuryC is only required when sending off server to the internet and then you would use the name of the ISPs SMTP host.
> queue location
c:\mercury\queue
> relay
> i'm sorry, but i cannot follow your instructions... A lot of these questions were answered in my first post, are you sure you read it? If you do not need the internet connection parts do not use them.  The process is simple, you install Pegasus Mail to c:\pmail as Multiuser using c:\pmail\mail as the mailbox location. You install Mercury/32 to c:\mercury using the defaults and then point it at the Pegasus Mail program (c:\pmail\programs) and mailbox (c:\pmail\mail) locations during the install. > > what i mean is..when i want to configure both pegasus and mercury to be > working in localhost only..no need internet connection. > > what is the right answer to put in these form... > > installingnew copy Pegasus Mail is installed to c:\pmail > > installation option Multiuser and the mail directory is c:\pmail\mail > > email address It's the local username and the domain you use when creating the users in Configuration | Manage local users.  For example, if you use mydomain.com in the Configuration | Mercury core | Domains and create a user called Admin then the e-mail address is admin@mydomain.com.  The Tools | Internet options | General entries are not required in a integrated setup. > > pop server If on the same system as Mercury then use 127.0.0.1.  The Tools | Internet options | (Receiving)POP3 is not required on an integrated setup. > > username and password The username is the name is the user you created in Mercury/32.  The password is the password you gave the user. > > smtp If on the same system as Mercury then use 127.0.0.1.  The Tools | Internet options | (Sending) SMTP is not required on an integrated setup.   > > and when installing mercury/32...these is the form.. > > where to install? c:\mercury > > integration with pagsus > > mailbox directory c:\pmail\mail\~n > > protocol to choose > > smtp client module MercuryC is only required when sending off server to the internet and then you would use the name of the ISPs SMTP host. > > basic configurations > > queue location c:\mercury\queue > > relay > > ok..these is the form that i dont know what to fill in...sorry for your > trouble..and thanx a lot for helping
