I'm not quite sure how to describe this and wasn't able to find anything with a cursory search.
I'm running Mercury v4.52 on an XP (sp3) machine.
There is one instance of Mercury showing in Windows "Task Mgr/Processes"
I have the Mercury GUI/Dialog open with sub-dialogs, Mercury Core Process and both STMP dialogs also open
Mercury has been busy sending out messages to our mailing list for the past hour and a half, but all sub-dislaogs have been idle and show no activity?
This cannot be normal! I understand this is not the most current version, but was part of a bundle, so I have been hesitant to upgrade it individually.
If this is a known issue and is addressed in the current version, I apologize for the unnecessary post.
I have not rebooted the server, since I would guess that will probably fix the current malfunction, but may make diagnostic more difficult. In case there's something you would like checked while it is still malfunctioning?!
Thanks for your time!
<p>I'm not quite sure how to describe this and wasn't able to find anything with a cursory search.</p><p>&nbsp;</p><p>I'm running Mercury v4.52 on an XP (sp3) machine.</p><p>There is one instance of Mercury showing in Windows "Task Mgr/Processes"</p><p>I have the Mercury GUI/Dialog open with sub-dialogs, Mercury Core Process and both STMP dialogs also open</p><p>Mercury has been busy sending out messages to our mailing list for the past hour and a half, but all sub-dislaogs have been idle and show no activity?</p><p>&nbsp;</p><p>This cannot be normal! I understand this is not the most current version, but was part of a bundle, so I have been hesitant to upgrade it individually.</p><p>If this is a known issue and is addressed in the current version, I apologize for the unnecessary post.</p><p>&nbsp;</p><p>I have not rebooted the server, since I would guess that will probably fix the current malfunction, but may make diagnostic more difficult. In case there's something you would like checked while it is still malfunctioning?!&nbsp;</p><p>&nbsp;</p><p>Thanks for your time!&nbsp;</p>
