Yes, tried...
File - Send all queued mail
No action. In fact, not even a TCP0001.WPM file was created.
I tried...
File - Check host for new mail
...and got a TCP00001.WPM file.
I tried...
File - check and send mail
...and strangely enough, I got three new TCPnnnn.WPM files, all identical to the first one. (so now I'm up to TCP00004.WPM in today's debugging)
I deleted all out going messages
I tried...
File - Check and send mail
Identical results again (by the way, that gives me two TCPnnnn.WPM files)
I tried sending a message to myself again; composing a one-line sentence, checking to see that it was in the queue, then...
File - send all queued mail
Hold it, I think it went across. What on earth could have happened ? Okay, here's TCP007.WPM...
--------------------STARTS---HERE--------------------------------
--- Sat, 22 Nov 2008 14:15:56 ---
Connect to 'smtp.charter.net' port 25, timeout 30.
14:15:56.828 [*] Connection established to 209.12.34.56
14:15:56.875 >> 0068 220 charter.net ESMTP server ready Sat, 22 Nov 2008 14:16:08 -0500\0D\0A
14:15:56.875 << 0023 EHLO [12.34.56.78]\0D\0A
14:15:56.906 >> 0017 250-charter.net\0D\0A
14:15:56.906 >> 0010 250-HELP\0D\0A
14:15:56.906 >> 0010 250-VRFY\0D\0A
14:15:56.906 >> 0018 250-XREMOTEQUEUE\0D\0A
14:15:56.906 >> 0010 250-ETRN\0D\0A
14:15:56.906 >> 0016 250-PIPELINING\0D\0A
14:15:56.906 >> 0009 250-DSN\0D\0A
14:15:56.906 >> 0014 250-8BITMIME\0D\0A
14:15:56.906 >> 0020 250 SIZE 524288000\0D\0A
14:15:56.906 << 0050 MAIL FROM:<TheDesiredAddress@MyRealDomain.com> SIZE=448\0D\0A
14:15:56.968 >> 0071 250 Sender <TheDesiredAddress@MyRealDomain.com> and extensions (SIZE=448) Ok\0D\0A
14:15:56.968 << 0039 RCPT TO:<TheDesiredAddress@MyRealDomain.com>\0D\0A
14:15:56.000 >> 0048 250 Recipient <TheDesiredAddress@MyRealDomain.com> Ok\0D\0A
14:15:56.000 << 0006 DATA\0D\0A
14:15:56.031 >> 0044 354 Ok Send data ending with <CRLF>.<CRLF>\0D\0A
14:15:56.031 << 0035 From: TheDesiredAddress@MyRealDomain.com\0D\0A
14:15:56.031 << 0033 To: TheDesiredAddress@MyRealDomain.com\0D\0A
14:15:56.031 << 0039 Date: Sat, 22 Nov 2008 14:15:56 -0500\0D\0A
14:15:56.031 << 0019 MIME-Version: 1.0\0D\0A
14:15:56.031 << 0025 Subject: Worthless test\0D\0A
14:15:56.031 << 0067 Message-ID: <9999999Z.88888.99ZZ9ZZZ@TheDesiredAddress.MyRealDomain.com>\0D\0A
14:15:56.031 << 0018 Priority: normal\0D\0A
14:15:56.031 << 0043 X-mailer: Pegasus Mail for Windows (4.41)\0D\0A
14:15:56.031 << 0044 Content-type: text/plain; charset=US-ASCII\0D\0A
14:15:56.031 << 0033 Content-transfer-encoding: 7BIT\0D\0A
14:15:56.031 << 0040 Content-description: Mail message body\0D\0A
14:15:56.031 << 0002 \0D\0A
14:15:56.031 << 0024 This test is worthless\0D\0A
14:15:56.031 << 0003 .\0D\0A
14:16:01.828 >> 0085 250 Message received: 20081122191608.ZZZZ9999.aarprv99.charter.net@[12.34.56.78]\0D\0A
14:16:01.828 << 0006 QUIT\0D\0A
14:16:01.859 >> 0049 221 charter.net ESMTP server closing connection\0D\0A
14:16:01.859 --- Connection closed normally at Sat, 22 Nov 2008 14:16:01. ---\0A\0A
---------------------ENDS----HERE--------------------------------
<P>Yes, tried...</P><P><EM>File - Send all queued mail</EM></P><P>No action. In fact, not even a TCP0001.WPM file was created.</P><P>I tried...</P><P><EM>File - Check host for new mail </EM></P><P>...and got a TCP00001.WPM file.</P><P>I tried...</P><P><EM>File - check and send mail</EM></P><P>...and strangely enough, I got three new TCPnnnn.WPM files, all identical to the first one. (so now I'm up to TCP00004.WPM in today's debugging)</P><P>I deleted all out going messages</P><P>I tried...</P><P><EM>File - Check and send mail</EM></P><P>Identical results again (by the way, that gives me two TCPnnnn.WPM files)</P><P>I tried sending a message to myself again; composing a one-line sentence, checking to see that it was in the queue, then...</P><P><EM>File - send all queued mail</EM></P><P>Hold it, I think it went across. What on earth could have happened ? Okay, here's TCP007.WPM...</P><P><STRONG>--------------------STARTS---HERE--------------------------------
</STRONG>--- Sat, 22 Nov 2008 14:15:56 ---
14:15:56.875 &gt;&gt; 0068 220 charter.net ESMTP server ready Sat, 22 Nov 2008 14:16:08 -0500\0D\0A
14:15:56.875 &lt;&lt; 0023 EHLO [12.34.56.78]\0D\0A
14:15:56.906 &gt;&gt; 0017 250-charter.net\0D\0A
14:15:56.906 &gt;&gt; 0010 250-HELP\0D\0A
14:15:56.906 &gt;&gt; 0010 250-VRFY\0D\0A
14:15:56.906 &gt;&gt; 0018 250-XREMOTEQUEUE\0D\0A
14:15:56.906 &gt;&gt; 0010 250-ETRN\0D\0A
14:15:56.906 &gt;&gt; 0016 250-PIPELINING\0D\0A
14:15:56.906 &gt;&gt; 0009 250-DSN\0D\0A
14:15:56.906 &gt;&gt; 0014 250-8BITMIME\0D\0A
14:15:56.906 &gt;&gt; 0020 250 SIZE 524288000\0D\0A
14:15:56.906 &lt;&lt; 0050 MAIL FROM:&lt;TheDesiredAddress@MyRealDomain.com&gt; SIZE=448\0D\0A
14:15:56.968 &gt;&gt; 0071 250 Sender &lt;TheDesiredAddress@MyRealDomain.com&gt; and extensions (SIZE=448) Ok\0D\0A
14:15:56.968 &lt;&lt; 0039 RCPT TO:&lt;TheDesiredAddress@MyRealDomain.com&gt;\0D\0A
14:15:56.000 &gt;&gt; 0048 250 Recipient &lt;TheDesiredAddress@MyRealDomain.com&gt; Ok\0D\0A
14:15:56.000 &lt;&lt; 0006 DATA\0D\0A
14:15:56.031 &gt;&gt; 0044 354 Ok Send data ending with &lt;CRLF&gt;.&lt;CRLF&gt;\0D\0A
14:15:56.031 &lt;&lt; 0035 From: TheDesiredAddress@MyRealDomain.com\0D\0A
14:15:56.031 &lt;&lt; 0033 To: TheDesiredAddress@MyRealDomain.com\0D\0A
14:15:56.031 &lt;&lt; 0039 Date: Sat, 22 Nov 2008 14:15:56 -0500\0D\0A
14:15:56.031 &lt;&lt; 0019 MIME-Version: 1.0\0D\0A
14:15:56.031 &lt;&lt; 0025 Subject: Worthless test\0D\0A
14:15:56.031 &lt;&lt; 0067 Message-ID: &lt;9999999Z.88888.99ZZ9ZZZ@TheDesiredAddress.MyRealDomain.com&gt;\0D\0A
14:15:56.031 &lt;&lt; 0018 Priority: normal\0D\0A
14:15:56.031 &lt;&lt; 0043 X-mailer: Pegasus Mail for Windows (4.41)\0D\0A
14:15:56.031 &lt;&lt; 0044 Content-type: text/plain; charset=US-ASCII\0D\0A
14:15:56.031 &lt;&lt; 0033 Content-transfer-encoding: 7BIT\0D\0A
14:15:56.031 &lt;&lt; 0040 Content-description: Mail message body\0D\0A
14:15:56.031 &lt;&lt; 0002 \0D\0A
14:15:56.031 &lt;&lt; 0024 This test is worthless\0D\0A
14:15:56.031 &lt;&lt; 0003 .\0D\0A
14:16:01.828 &gt;&gt; 0085 250 Message received: 20081122191608.ZZZZ9999.aarprv99.charter.net@[12.34.56.78]\0D\0A
14:16:01.828 &lt;&lt; 0006 QUIT\0D\0A
14:16:01.859 &gt;&gt; 0049 221 charter.net ESMTP server closing connection\0D\0A
<STRONG>---------------------ENDS----HERE--------------------------------
</STRONG></P>
