Pegasus won't load
Thanks Thomas.
I moved the CNM files this time too, and it started.  The new ones were all small, so I'm not sure what the problem is.  I had thought the problem was with big files.
Anyway, It's working, so that's what I need.  Thanks again.
<p> Thanks Thomas.</p><p>I moved the CNM files this time too, and it started.  The new ones were all small, so I'm not sure what the problem is.  I had thought the problem was with big files.</p><p>Anyway, It's working, so that's what I need.  Thanks again. </p>
Hi:
 My Pegasus won't load past the point where it says its getting the folders.
 I have looked at  CNM files, and they're OK, then I remembered that one time I thought I had to rename Hierarch.PM, so I tried sticking a "2" in just before the dot, but that didn't work either.
Any other ideas - or did I do the Hierarch thing wrong?
Thanks, gotta go to the office now :-(( but back in a few hours.
~marilyn
<p>Hi:</p><p> My Pegasus won't load past the point where it says its getting the folders.</p><p> I have looked at  CNM files, and they're OK, then I remembered that one time I thought I had to rename Hierarch.PM, so I tried sticking a "2" in just before the dot, but that didn't work either.</p><p>Any other ideas - or did I do the Hierarch thing wrong?</p><p>Thanks, gotta go to the office now :-(( but back in a few hours.</p><p>~marilyn </p>
As long as yuo did this re-name without the program running it should work.   I still would move the CNM files out of the new mail directory and try again though.
<blockquote>Any other ideas - or did I do the Hierarch thing wrong?</blockquote><p>As long as yuo did this re-name without the program running it should work.   I still would move the CNM files out of the new mail directory and try again though.</p><p> </p>
