Help please
Thanks for your help ill have a look
Cheers
Stew.
<P>Thanks for your help ill have a look </P> <P>Cheers </P> <P>Stew.</P>
Hi all im new here so be gental please[:D]
I have a PC that is not connected onto a network that is ussing Pegasus for emails.  I need to save these emails off as a PST folder somehoew and tranport them to a networked PC into outlook and add them to the archive.  is their a way i can do this easily? or anyother way which will be qick and easy.  T
Stew.
<P mce_keep="true"> </P> <P>Hi all im new here so be gental please[:D] </P> <P>I have a PC that is not connected onto a network that is ussing Pegasus for emails.  I need to save these emails off as a PST folder somehoew and tranport them to a networked PC into outlook and add them to the archive.  is their a way i can do this easily? or anyother way which will be qick and easy.  T</P> <P mce_keep="true"> </P> <P>Thanks, </P> <P>Stew. </P>
> for emails.  I need to save these emails off as a PST folder somehow
> and transport them to a networked PC and add them to the archive.  is
> their a way i can do this easily? or any other way which will be quick
> and easy.
There are a couple of commercial programs to do this  type of conversion.
Aid4mail
       http://www.aid4mail.com/
Transend
       http://www.transend.com/
You might want to check out the converters available at the following site as well.
       http://www.emailman.com/conversion/#mboxwin
> I have a PC that is not connected onto a network that is ussing Pegasus > for emails.  I need to save these emails off as a PST folder somehow > and transport them to a networked PC and add them to the archive.  is > their a way i can do this easily? or any other way which will be quick > and easy.  There are a couple of commercial programs to do this  type of conversion. Aid4mail        http://www.aid4mail.com/ Transend        http://www.transend.com/ You might want to check out the converters available at the following site as well.        http://www.emailman.com/conversion/#mboxwin
