Mail sending problems (Again)
Yes I did.....but I must tell you after I signed off the forum and shut down computer
due to a couple of office meetings I had and then coming back and turning computer back on
everything was normal....I don't get it at all. In essesnce we're back to normal but never thought I
would have to that in order to regain the send faction, As mentioned I received okay all along.
Thanks for reading AND your support for being there. Maybe i should think about changing
the password workings.
<p>Yes I did.....but I must tell you after I signed off the forum and shut down computer</p><p> due to a couple of office meetings I had and then coming back and turning computer back on</p><p>everything was normal....I don't get it at all. In essesnce we're back to normal but never thought I</p><p>would have to that in order to regain the send faction, As mentioned I received okay all along.</p><p>Thanks for reading AND your support for being there. Maybe i should think about changing </p><p>the password workings. </p><p> </p>
Having mail problems again (isp verizon) ....receiving but unable to send. I have gone to network config...and to SMTP and hit security tab and chose one of the choices but still a no go
[*] Connection established to 206.46.232.12
>> 0110 220 vms173001pub.verizon.net -- Server ESMTP (Sun Java System Messaging Server 6.2-6.01 (built Apr  3 2006))
<< 0022 EHLO [192.168.2.104]
>> 0030 250-vms173001pub.verizon.net
>> 0014 250-8BITMIME
>> 0016 250-PIPELINING
>> 0009 250-DSN
>> 0025 250-ENHANCEDSTATUSCODES
>> 0010 250-HELP
>> 0044 250-XLOOP 1D36D1188318EBD9D178C75F9DCC0070
>> 0022 250-AUTH PLAIN LOGIN
>> 0016 250-AUTH=LOGIN
>> 0010 250-ETRN
>> 0019 250-NO-SOLICITING
>> 0019 250 SIZE 20971520
<< 0012 AUTH LOGIN
>> 0018 334 VXNlcm5hbWU6
<< 0014 ZHNtY2dpbGw=
>> 0018 334 UGFzc3dvcmQ6
<< 0022 NDNDaGF1dGF1cXVhNDY=
>> 0078 535 5.7.8 Authorization failure (Not authorized to login as specified user).
&lt;p&gt;Having mail problems again (isp verizon) ....receiving but unable to send. I have gone to network config...and to SMTP and hit security tab and chose one of the choices but still a no go &lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;[*] Connection established to 206.46.232.12 &amp;gt;&amp;gt; 0110 220 vms173001pub.verizon.net -- Server ESMTP (Sun Java System Messaging Server 6.2-6.01 (built Apr&amp;nbsp; 3 2006)) &amp;lt;&amp;lt; 0022 EHLO [192.168.2.104] &amp;gt;&amp;gt; 0030 250-vms173001pub.verizon.net &amp;gt;&amp;gt; 0014 250-8BITMIME &amp;gt;&amp;gt; 0016 250-PIPELINING &amp;gt;&amp;gt; 0009 250-DSN &amp;gt;&amp;gt; 0025 250-ENHANCEDSTATUSCODES &amp;gt;&amp;gt; 0010 250-HELP &amp;gt;&amp;gt; 0044 250-XLOOP 1D36D1188318EBD9D178C75F9DCC0070 &amp;gt;&amp;gt; 0022 250-AUTH PLAIN LOGIN &amp;gt;&amp;gt; 0016 250-AUTH=LOGIN &amp;gt;&amp;gt; 0010 250-ETRN &amp;gt;&amp;gt; 0019 250-NO-SOLICITING &amp;gt;&amp;gt; 0019 250 SIZE 20971520 &amp;lt;&amp;lt; 0012 AUTH LOGIN &amp;gt;&amp;gt; 0018 334 VXNlcm5hbWU6 &amp;lt;&amp;lt; 0014 ZHNtY2dpbGw= &amp;gt;&amp;gt; 0018 334 UGFzc3dvcmQ6 &amp;lt;&amp;lt; 0022 NDNDaGF1dGF1cXVhNDY= &amp;gt;&amp;gt; 0078 535 5.7.8 Authorization failure (Not authorized to login as specified user). &lt;/p&gt;
It does not like the username and password you supplied.  The why is a bit more of a problem.  Did you select the second AUTH option and enter a specific username and password?
&lt;p&gt;It does not like the username and password you supplied.&amp;nbsp; The why is a bit more of a problem.&amp;nbsp; Did you select the second AUTH option and enter a specific username and password?&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;
