Environment:  Novell Netware 6.5 OES, Windows XP clients, OO.org versions 2.4 and 3.0, Pegasus Mail version 4.31 in network mode, Mercury/32.
Trying to use the File, Send command to send an OO document via email. Something is not quite right.  IWhen you use the command, the OO document seems to freeze.  I can manually switch over to the Pegasus Mail screen and it will be shrunk down--not minimized, but in a smaller window. If you finally close the OO document (well, you have to crash it), then it does eventually display a message in Pegasus that says "Please wait transferring to Pegasus Mail" , followed by a Pegasus Mail MAPI Interface window that says "Transfer of information complete. Please switch to Pegasus Mail using ALT-TAB to complete your message.  Because temporary files may have been created, you should ensure that you send your message before returning to theis application."  When I click close on that window, I have the empty new message window and there is an attachment.  But I can't figure out why it will not complete unless I close out of OO?  Anyone tried this before and get it to work?  It does the same thing whether I send the document as email, as PDF, etc.
 Any ideas?
Thanks, Gromit
        <p>Environment:&nbsp; Novell Netware 6.5 OES, Windows XP clients, OO.org versions 2.4 and 3.0, Pegasus Mail version 4.31 in network mode, Mercury/32.
</p><p>Trying to use the File, Send command to send an OO document via email. Something is not quite right.&nbsp; IWhen you use the command, the OO document seems to freeze.&nbsp; I can manually switch over to the Pegasus Mail screen and it will be shrunk down--not minimized, but in a smaller window. If you finally close the OO document (well, you have to crash it), then it does eventually display a message in Pegasus that says "Please wait transferring to Pegasus Mail" , followed by a Pegasus Mail MAPI Interface window that says "Transfer of information complete. Please switch to Pegasus Mail using ALT-TAB to complete your message.&nbsp; Because temporary files may have been created, you should ensure that you send your message before returning to theis application."&nbsp; When I click close on that window, I have the empty new message window and there is an attachment.&nbsp; But I can't figure out why it will not complete unless I close out of OO?&nbsp; Anyone tried this before and get it to work?&nbsp; It does the same thing whether I send the document as email, as PDF, etc.</p><p>&nbsp;Any ideas?</p><p>&nbsp;</p><p>Thanks, Gromit
