problem with attachments
I suggest you check if either Temp or Tmp environment variables are set.  In P.M. Help menu, go into the About Pegasus Mail menu item and click info button.
If they are not set (typically point to your My Documents\Local Settings\Temp directory or c:\temp) you will need to set them up, via Control Panel/System/Advanced/Environmental Variables.
HTH
<p>I suggest you check if either Temp or Tmp environment variables are set.  In P.M. Help menu, go into the About Pegasus Mail menu item and click info button.</p><p>If they are not set (typically point to your My Documents\Local Settings\Temp directory or c:\temp) you will need to set them up, via Control Panel/System/Advanced/Environmental Variables. </p><p>HTH</p><p>Martin </p>
Recently had to re-install Windows XP operating system and Pegasus mail. Since re-installation I have not been able to attach any type of file to my emails.  The result of an attempt is to cause an error message for sending off to Microsoft and then Pegasus shuts down. any suggestion on how to fix the problem? I have been using Pegasus for over 10 years and have never had this problem before
