[quote user="LynnL"]
Wonderful [:)]
Thank you, I had totally forgotten about the desktop state not being saved between sessions by default.
Now enabled and working but.............. none of the settings (of Debra's folders) are in their normal format i.e. all the message folders are there but they are not in folders (filing trays) as per the view in Debra's.
Any idea on how to do that?
Thanks.
Lynn[/quote]
That's by design. You can have your own "view"on how to store/group mailboxes. E.g. if you want only some folders to see create a "Will not see" tray and store all folders that you will not see in it, that way you can only pick out the important folders.
Just FYI: The new mail count will NOT update when new mail arrives in the new mail folder of an added mailbox.
[quote user="LynnL"]<p>Wonderful [:)]</p><p>Thank you, I had totally forgotten about the desktop state not being saved between sessions by default.
Thanks.
Lynn[/quote]</p><p>That's by design. You can have your own "view"on how to store/group mailboxes. E.g. if you want only some folders to see create a "Will not see" tray and store all folders that you will not see in it, that way you can only pick out the important folders. </p><p>Just FYI: The new mail count will NOT update when new mail arrives in the new mail folder of an added mailbox.</p><p>&nbsp;</p><p>&nbsp;</p><p>&nbsp;</p>
Han van den Bogaerde - support@vandenbogaerde.net
Member of Pegasus Mail Support Group.
My own Pegasus Mail related web information:
http://www.vandenbogaerde.net/pegasusmail/
