There is no support for POP3 or IMAP in the program. Can anyone tell me if I can continue to use pegasus and if so how to configure the software to run in the new environment.
Since PMail can only connect to Exchange via IMAP4 or POP3 you are pretty much out of luck unless they provide some sort of webmail service that can be used with Mr Postman. Since Mr Postman says it can do Outlook Web Access you might give it a try.
MrPostman is a java program that allows you to access Yahoo Mail, Hotmail and other webmail services directly from your favorite mail client.
It converts the web pages of your favorite webmail provider to e-mails and provides the standard POP interface to your mail client (e.g. Outlook Express, Netscape or Mozilla Mail, Thunderbird, Pegasus Mail).
MrPostman is Free Software, released under the terms of the GNU Public License.
Currently supported webmail providers:
* Hotmail
* mail.com
* Yahoo
* gmail (Google mail)
* indiatimes.com
* juno
* rediffmail
* Gossamer mail
* Outlook Web Access (Exchange 5.5)
* Outlook Web Access 2003
http://sourceforge.net/projects/mrpostman/
<blockquote>There is no support for POP3 or IMAP in the program.&nbsp; Can anyone tell me if I can continue to use pegasus and if so how to configure the software to run in the new environment. </blockquote><p>Since PMail can only connect to Exchange via IMAP4 or POP3 you are pretty much out of luck unless they provide some sort of webmail service that can be used with Mr Postman.&nbsp; Since Mr Postman&nbsp; says it can do Outlook Web Access you might give it a try.
</p><p><font size="3" face="times new roman,times">MrPostman is a java program that allows you to access Yahoo Mail, Hotmail and other webmail services directly from your favorite mail client.&nbsp;
It converts the web pages of your favorite webmail provider to e-mails and provides the standard POP interface to your mail client (e.g. Outlook Express, Netscape or Mozilla Mail, Thunderbird, Pegasus Mail).&nbsp;
&nbsp;&nbsp;&nbsp; * Hotmail
&nbsp;&nbsp;&nbsp; * mail.com
&nbsp;&nbsp;&nbsp; * Yahoo
&nbsp;&nbsp;&nbsp; * gmail (Google mail)
&nbsp;&nbsp;&nbsp; * indiatimes.com
&nbsp;&nbsp;&nbsp; * juno
&nbsp;&nbsp;&nbsp; * rediffmail
&nbsp;&nbsp;&nbsp; * Gossamer mail
&nbsp;&nbsp;&nbsp;<b> * Outlook Web Access (Exchange 5.5)
&nbsp;&nbsp;&nbsp; * Outlook Web Access 2003</b>
http://sourceforge.net/projects/mrpostman/</font>
