clamav for window problem
Hi all
i just installed the new vesion of clamwall to 1.4 and upgrade to clamav 095a
all work fine!!
thanks a lot for this great support!!!
Victor
<P>Hi all</P> <P>i just installed the new vesion of clamwall to 1.4 and upgrade to clamav 095a</P> <P mce_keep="true"> </P> <P>all work fine!!</P> <P mce_keep="true"> </P> <P>thanks a lot for this great support!!!</P> <P mce_keep="true"> </P> <P>Victor</P>
Hi.
we have a mercury/32 v4.62 installation working fine with clamav antivirus plugin running with the v094-1 clamav version.
yesterday we update clamav from 094-1 to 0.95 and the mercury core proccess stop work without any error or message....  rolled out to 094-1 version all become ok again..
someone have any info about this???
<P>Hi.</P> <P>we have a mercury/32 v4.62 installation working fine with clamav antivirus plugin running with the v094-1 clamav version.</P> <P mce_keep="true"> </P> <P>yesterday we update clamav from 094-1 to 0.95 and the mercury core proccess stop work without any error or message....  rolled out to 094-1 version all become ok again..</P> <P mce_keep="true"> </P> <P>someone have any info about this???</P> <P mce_keep="true"> </P>
tBB and others have reported that 0.95 has different responses, so it may be that.  For the moment continue with the previous Clamav version.
[quote user="vmgracia"]
As it looks ClamWall uses a command in it's communication with the ClamD daemon which is obsolete in ClamAV 0.95. I've already written Lukas a mail about the issue so hopefully this will be resolved quickly.
Best regards,
Nico
[quote user="vmgracia"]<P>someone have any info about this???</P> <P mce_keep="true">[/quote]</P><P mce_keep="true">As it looks ClamWall uses a command in it's communication with the ClamD daemon which is obsolete in ClamAV 0.95. I've already written Lukas a mail about the issue so hopefully this will be resolved quickly.</P><P mce_keep="true"></P><P mce_keep="true">Best regards,</P><P mce_keep="true">Nico</P>
Any news on a new clamwall version?
<P>Any news on a new clamwall version?</P><P>Thanks</P>
[quote user="keithy"]
http://www.ararat.cz/download/clamwallsetup-1.4.0.exe
Best regards,
Nico
[quote user="keithy"]<P>Any news on a new clamwall version?</P><P>[/quote]</P><P>http://www.ararat.cz/download/clamwallsetup-1.4.0.exe</P><P> </P><P>Best regards,</P><P>Nico</P>
Thanks Nico,
Is this safe for production use? sadly theres no info (nor even a link) on the clamwall website!
Cheers
keith
<P>Thanks Nico,</P><P>Is this safe for production use? sadly theres no info (nor even a link) on the clamwall website!</P><P>Cheers</P><P>keith</P>
Short answer: Well..if it works, yes :)
Long answer: The changes in this ClamWall version are not that spectacular and Lukas tends to release stable code ;) As for the webpage, usually it takes a while until Lukas updates it but the update notice already went over the Mercury mailing list.
Best regards,
Nico
[quote user="keithy"]<P>Is this safe for production use? sadly theres no info (nor even a link) on the clamwall website!</P><P>[/quote]</P><P>Short answer: Well..if it works, yes :) </P><P>Long answer: The changes in this ClamWall version are not that spectacular and Lukas tends to release stable code ;) As for the webpage, usually it takes a while until Lukas updates it but the update notice already went over the Mercury mailing list.</P><P> </P><P>Best regards,</P><P>Nico</P>
Nico,
Thanks for your assurances - works a treat :)
Also accept my gratitude for all your hard work on ClamAV and clamsup!
Regards
Keith
<P>Nico, </P><P>Thanks for your assurances - works a treat :)</P><P>Also accept my gratitude for all your hard work on ClamAV and clamsup!</P><P>Regards</P><P>Keith</P>
Nico,
 Thanks for helping to be the link in the middle to get ClamAV and ClamWall working again.  It's all working great along with ClamSup.
Later.....................
<P>Nico,</P> <P> Thanks for helping to be the link in the middle to get ClamAV and ClamWall working again.  It's all working great along with ClamSup.</P> <P>Later.....................</P>
