--- Wed, 15 Apr 2009 08:49:44 ---
Connect to 'mail.mtco.com' port 995, timeout 60.
08:50:05.421 5: Connect failed, 274C.
Go to this URl for their instructions:
http://email.mtco.com/
I used the Thunderbird stuff:
Thunderbird Text Instructions
1.
Open Thunderbird. At the top click Tools -> Account Settings.
2.
On the left, under your mail account (user@mtco.com) click "Server Settings".
3.
On the right, underneath the "Security Settings" heading, switch from Never to SSL.
Changing this setting should cause the Port at the top to go from 110 to 995.
If not, change manually.
4.
On the left, click "Outgoing Server (SMTP)" to change the outgoing settings.
5.
On the right, the outgoing server should say smtp.mtco.com. Click the Edit button next to it.
6.
At the bottom, underneath "Security and Authentication", checkmark "Use name and password".
The username should already be your MTCO username. If not, add manually.
7.
Below the username section, switch the "Use Secure Connection" setting from No to SSL.
This should also change the port number above from 25 to 465. If not, change manually.
8.
Click OK twice to save.
I tried about everything with authentication, certificates. MTCO said Pegasus mail just does not work with them.
Jerry Gunn
<P>--- Wed, 15 Apr 2009 08:49:44 ---
08:50:05.421 5: Connect failed, 274C.</P>
<P>Go to this URl for their instructions:</P>
<P><A href="http://email.mtco.com/">http://email.mtco.com/</A></P>
<P><EM>I used&nbsp; the Thunderbird stuff:</EM></P>
<P><FONT face=Verdana><STRONG>Thunderbird Text Instructions</STRONG>
1.<IMG height=0 src="http://email.mtco.com/images/fill.gif" width=12 border=0> Open Thunderbird. At the top click Tools -&gt; Account Settings.
2.<IMG height=0 src="http://email.mtco.com/images/fill.gif" width=12 border=0> On the left, under your mail account (user@mtco.com) click "Server Settings".
3.<IMG height=0 src="http://email.mtco.com/images/fill.gif" width=12 border=0> On the right, underneath the "Security Settings" heading, switch from Never to SSL.
&nbsp; &nbsp; <IMG height=0 src="http://email.mtco.com/images/fill.gif" width=12 border=0> Changing this setting should cause the Port at the top to go from 110 to 995.
&nbsp; &nbsp; <IMG height=0 src="http://email.mtco.com/images/fill.gif" width=12 border=0> If not, change manually.
4.<IMG height=0 src="http://email.mtco.com/images/fill.gif" width=12 border=0> On the left, click "Outgoing Server (SMTP)" to change the outgoing settings.
5.<IMG height=0 src="http://email.mtco.com/images/fill.gif" width=12 border=0> On the right, the outgoing server should say smtp.mtco.com. Click the Edit button next to it.
6.<IMG height=0 src="http://email.mtco.com/images/fill.gif" width=12 border=0> At the bottom, underneath "Security and Authentication", checkmark "Use name and password".
&nbsp; &nbsp; <IMG height=0 src="http://email.mtco.com/images/fill.gif" width=12 border=0> The username should already be your MTCO username. If not, add manually.
7.<IMG height=0 src="http://email.mtco.com/images/fill.gif" width=12 border=0> Below the username section, switch the "Use Secure Connection" setting from No to SSL.
&nbsp; &nbsp; <IMG height=0 src="http://email.mtco.com/images/fill.gif" width=12 border=0> This should also change the port number above from 25 to 465. If not, change manually.
8.<IMG height=0 src="http://email.mtco.com/images/fill.gif" width=12 border=0> Click OK twice to save.&nbsp;</FONT>&nbsp;</P>
<P mce_keep="true">&nbsp;</P>
<P>I tried about everything with authentication, certificates.&nbsp; MTCO said Pegasus mail just does not work with them.&nbsp;</P>
<P>Jerry Gunn</P>
