Hello all,
I am having the following problem with receiving mail and the error message is copied below. When the mail is accessed using the webmail (Horde) utility, there are currently 2 messages in the inbox. (The webmail figure bizarrely shows 3, but only 2 are seen). They are not large mails, both being under 200 kb.
What would cause the following message?
[*] Connection established to 204.244.125.10
>> 0058 +OK Hello there. <8981.1240167172@localhost.localdomain>
<< 0031 USER email@xxxx.com
>> 0024 +OK Password required.
<< 0014 PASS XXXXXXX
>> 0016 +OK logged in.
<< 0006 STAT
>> 0014 +OK 3 438049
<< 0006 LIST
>> 0055 +OK POP3 clients that break here, they violate STD53.
<< 0008 UIDL 1
>> 0024 +OK 1 UID25-1239911524
<< 0009 TOP 1 1
>> 0047 -ERR Can't open the message file - it's gone!
Many thanks in advance.
Ellie
<p>Hello all,</p><p>&nbsp;I am having the following problem with receiving mail and the error message is copied below. When the mail is accessed using the webmail (Horde) utility, there are currently 2 messages in the inbox. (The webmail figure bizarrely shows 3, but only 2 are seen). They are not large mails, both being under 200 kb.</p><p>What would cause the following message?
</p><p>[*] Connection established to 204.244.125.10
&gt;&gt; 0058 +OK Hello there. &lt;8981.1240167172@localhost.localdomain&gt;
&lt;&lt; 0031 USER email@xxxx.com
&gt;&gt; 0024 +OK Password required.
&lt;&lt; 0014 PASS XXXXXXX
&gt;&gt; 0016 +OK logged in.
&lt;&lt; 0006 STAT
&gt;&gt; 0014 +OK 3 438049
&lt;&lt; 0006 LIST
&gt;&gt; 0055 +OK POP3 clients that break here, they violate STD53.
&lt;&lt; 0008 UIDL 1
&gt;&gt; 0024 +OK 1 UID25-1239911524
&lt;&lt; 0009 TOP 1 1
&gt;&gt; 0047 -ERR Can't open the message file - it's gone!</p><p>Many thanks in advance.</p><p>Ellie
