[quote user="David H. Lipman"]
Reference Usenet: Message-ID: <38u2v49n17p9s3m08u589fmvds52b6norq@4ax.com>
{ I PREFER Usenet ! }
I know, but these days it looks like an antique in extinction ...
I sent my self a digitally signed email. My recipient PC has all the chain's certificates in the certificate store. However I get...
"However the issuer of the certificate used for signing could not be
verified"
I have all the needed certificates in the chain including the Root Certificate. I even verified this.
From my Usenet reply:
[quote user="idw"]
Well, the system itself is reporting this error, so something must be wrong: (...) Did you check the (issuer's) certificate resp. the certificate chain (manually, i.e. via button/menu entry, because it may take some time)?
The below URL displays the dialog you should get, does it show a similar message?
<http://technet.microsoft.com/en-us/library/cc962071.aspx>.
Maybe the issuer's certificate is not in the "Trusted Root Certificates" store, see <http://technet.microsoft.com/en-us/library/cc940384.aspx>.
Sorry, but certificate management (like key management with PGP) is a rather demanding issue if you don't use standard certificates issued by roots pre-installed by IE (I'm not saying I prefer it this way, it's just a matter of fact).
The automated verification is less strict in that it only checks the local certificate store for the certificate chain (which is usually included in the signed message anyway) and revocation lists etc. because otherwise you may have to wait until it times out before a message gets displayed. It shouldn't fail on verifying the (self-signed) root certificate, though, at least if it has been installed into your Trusted Root Certificates store.
If you've done this already can you please send a signed message to my personal email address (shown on the extension's "About ..." Dialog) so I can check this issue?
[quote user="David H. Lipman"]<p>Reference Usenet: Message-ID: &lt;38u2v49n17p9s3m08u589fmvds52b6norq@4ax.com&gt;</p><p>{ <span style="font-weight: bold; font-style: italic;">I PREFER Usenet ! </span>} </p><p>[/quote]</p><p>I know, but these days it looks like an antique in extinction ...</p><p>[quote user="David H. Lipman"]
</p>&nbsp;I sent my self a digitally signed email. My recipient PC has all the chain's certificates in the certificate store.&nbsp; However I get...<p>"However the issuer of the certificate used for signing could not be
verified"</p><p>I have all the needed certificates in the chain including the Root Certificate.&nbsp; I even verified this.</p><p>[/quote]</p><p>From my Usenet reply:</p><p>[quote user="idw"] </p><p>Well, the system itself is reporting this error, so something must be wrong: (...) Did you check the (issuer's) certificate resp. the certificate chain (manually, i.e. via button/menu entry, because it may take some time)?
&lt;<a href="http://technet.microsoft.com/en-us/library/cc962071.aspx" target="_blank" mce_href="http://technet.microsoft.com/en-us/library/cc962071.aspx">http://technet.microsoft.com/en-us/library/cc962071.aspx</a>&gt;.
Maybe the issuer's certificate is not in the "Trusted Root Certificates" store, see &lt;<a href="http://technet.microsoft.com/en-us/library/cc940384.aspx" target="_blank" mce_href="http://technet.microsoft.com/en-us/library/cc940384.aspx">http://technet.microsoft.com/en-us/library/cc940384.aspx</a>&gt;.
[/quote]</p><p>The automated verification is less strict in that it only checks the local certificate store for the certificate chain (which is usually included in the signed message anyway) and revocation lists etc. because otherwise you may have to wait until it times out before a message gets displayed. It shouldn't fail on verifying the (self-signed) root certificate, though, at least if it has been installed into your <i>Trusted Root Certificates</i> store.</p><p>If you've done this already can you please send a signed message to my personal email address (shown on the extension's "About ..." Dialog) so I can check this issue?
