Path-placeholder /-variable for home-directory?
We have all homedirecories, e.g.
//server/home/company/last_name/
this
path would like %homepath% in Windows (for each user), and after the
homepath is the pmail-folder with the mails. (also %homepath%\pmail\ )
Also we only need some variable which does the same like %homepath% in windows
The mailbox directories in Mercury must be in the same location, i.e. \\server\home\company\last_name\pmail  so the only variable you can use the the ~8 or ~n  in the place of the last_name.  If you have multiple paths to different servers and directories them that means each of these must be managed by their own Mercury/32 installation.
I'm not even positive you can still use the \\server\home\company\~n\pmail format for the mailbox directory spec since it is not really officially supported except with NDS in a Netware setup.  I have used it in the past and it did work for me but I've not used it in at least a couple of years.
<blockquote><p>We have all homedirecories, e.g.</p><p>//server/home/company/last_name/</p><p>this path would like %homepath% in Windows (for each user), and after the homepath is the pmail-folder with the mails. (also %homepath%\pmail\ ) </p><p>Also we only need some variable which does the same like %homepath% in windows </p></blockquote><p>The mailbox directories in Mercury must be in the same location, i.e. \\server\home\company\last_name\pmail  so the only variable you can use the the ~8 or ~n  in the place of the last_name.  If you have multiple paths to different servers and directories them that means each of these must be managed by their own Mercury/32 installation.  </p><p>I'm not even positive you can still use the \\server\home\company\~n\pmail format for the mailbox directory spec since it is not really officially supported except with NDS in a Netware setup.  I have used it in the past and it did work for me but I've not used it in at least a couple of years. </p>
Heyho =)
 I think that I'm too stupid to find some good answeres for my question. I'd asked Google for more than 5 hourse after the key-words: "mercury mail + variable + windows home directory ^^
Ok, my problem:
I've 2 servers, one is my mailserver (and s.o.) and another server is my homeserver with all groups and users.
I'll push mails from user1@grp1.com to \\homeserver\home_dir\group1\user1\pmail\
but e.g. user1@grp2.com to \\homeserver\home_dir\group2\user1\pmail\
.. and so on...
Also I need some placeholder:
\\homeserver\home_dir\%group%\%user%\pmail\
How can I realize this?
greetz
Nira
PS:
%user% is ~8 or ~n in mercury, right?
<p>Heyho =)</p><p> I think that I'm too stupid to find some good answeres for my question. I'd asked Google for more than 5 hourse after the key-words: "mercury mail + variable + windows home directory ^^ </p><p>Ok, my problem:</p><p>I've 2 servers, one is my mailserver (and s.o.) and another server is my homeserver with all groups and users.</p><p>I'll push mails from user1@grp1.com to \\homeserver\home_dir\group1\user1\pmail\</p><p>but e.g. user1@grp2.com to \\homeserver\home_dir\group2\user1\pmail\</p><p>.. and so on...</p><p> </p><p>Also I need some placeholder:</p><p>\\homeserver\home_dir\%group%\%user%\pmail\</p><p> </p><p>How can I realize this?</p><p> </p><p>greetz</p><p>Nira </p><p> </p><p>PS:</p><p>%user% is ~8 or ~n in mercury, right? </p>
Mercury/32 does not do groups on Windows but as you stated you can replace the username with either ~8 or ~n.  The ~8 is limited to 8 characters, the ~n can be more but no special characters.  I've used \\server\volume\users\~8\pmail and it works just fine.  Note the lack of a trailing backspace.
Edit: Oops sent to fast!  What you could do is run a copy of Mercury/32 for each group  using a different MercuryS port for each server with the mailbox spec of \\homeserver\home_dir\group\~8\pmail and then forward the mail using WSMTPEx.exe to the proper Mercury/32 server.  You can run multiple copies of Mercury on the same system as long as you keep then using separate directory structures and ports.
<blockquote><p>Also I need some placeholder:</p><p>\\homeserver\home_dir\%group%\%user%\pmail\</p><p>How can I realize this?</p></blockquote><p>Mercury/32 does not do groups on Windows but as you stated you can replace the username with either ~8 or ~n.  The ~8 is limited to 8 characters, the ~n can be more but no special characters.  I've used \\server\volume\users\~8\pmail and it works just fine.  Note the lack of a trailing backspace.  </p><p>Edit: Oops sent to fast!  What you could do is run a copy of Mercury/32 for each group  using a different MercuryS port for each server with the mailbox spec of \\homeserver\home_dir\group\~8\pmail and then forward the mail using WSMTPEx.exe to the proper Mercury/32 server.  You can run multiple copies of Mercury on the same system as long as you keep then using separate directory structures and ports. </p><p> </p>
Hey! =)
Thank you for your answere! =)
I'm sorry, but I've misunderstood the problem from my admin... [:O]
Ok, I'll start again...
I hope I have now explained and understood right :D
Nira
<p>Hey! =)</p><p>Thank you for your answere! =)</p><p>I'm sorry, but I've misunderstood the problem from my admin... [:O]</p><p> </p><p>Ok, I'll start again...</p><p>We have all homedirecories, e.g.</p><p>//server/home/company/last_name/</p><p>this path would like %homepath% in Windows (for each user), and after the homepath is the pmail-folder with the mails. (also %homepath%\pmail\ ) </p><p>Also we only need some variable which does the same like %homepath% in windows </p><p> </p><div style="text-align: left;" id="result_box" dir="ltr">I hope I have now explained and understood right :D</div><div style="text-align: left;" id="result_box" dir="ltr">Nira </div><p> </p><p> </p>
This topic is closed
Related Topics
