When a user logs in the program will count the number of messages in the Inbox and add up the size. If there are a lot of messages this could, depending on the speed and load of the server, take some time, but that should anyhow not be a very long time.
There is a slightly newer version of the program available here in case that could help.
(If you double-click the log listbox to the right the contents will be copied to a file in the same directory as the program.)
<p>When a user logs in the program will count the number of messages in the Inbox and add up the size. If there are a lot of messages this could, depending on the speed and load of the server, take some time, but that should anyhow not be a very long time.
</p><p>There is a slightly newer version of the program available <a href="http://83.140.29.200/HTTPServer.zip" target="_blank" mce_href="http://83.140.29.200/HTTPServer.zip">here</a> in case that could help.
</p><p>(If you double-click the log listbox to the right the contents will be copied to a file in the same directory as the program.)</p><p>/Rolf
