[quote user="StephenKovacsiss"]
I have been using PMail for many years and today attempted to use the RQuotes variable signature feature.  I was able to successfully compile the RSC file and then copy it to my mail folder as a PMS file.  If I edit the Signature to include a ~! where I would like the quote, when it attempts to add the signature, PMAIL hangs.  If I check Task Manager, it is running full CPU resource and does not stop until I Stop the Process.  I left it for nearly 5 minutes the second time.  I then tried to use the default RQUOTES.R and created the RSC and PMS from that.  Same issue.  If I remove the file, program works fine.  If I remove the ~! from sig, it works fine.  Add both back in and it hangs.  I have tried this on both a C Drive install and my Windows shared network install with the same results.
Any help would be appreciated.
Best Regards,
Stephen Kovacsiss
I had this problem also when setting up Plato which, I think, is essentially the same thing you're trying to do.  The only way the quote feature worked without hanging was to use the quote only in plain content.  If I tried to add the quote in formatted content with the "add varient at message creation" box checked, pmail would hang as soon as I opened a new message.
<P>I have been using PMail for many years and today attempted to use the RQuotes variable signature feature.&nbsp; I was able to successfully compile the RSC file and then copy it to my mail folder as a PMS file.&nbsp; If I edit the Signature to include a ~! where I would like the quote, when it attempts to add the signature, PMAIL hangs.&nbsp; If I check Task Manager, it is running full CPU resource and does not stop until I Stop the Process.&nbsp; I left it for nearly 5 minutes the second time.&nbsp; I then tried to use the default RQUOTES.R and created the RSC and PMS from that.&nbsp; Same issue.&nbsp; If I remove the file, program works fine.&nbsp; If I remove the ~! from sig, it works fine.&nbsp; Add both back in and it hangs.&nbsp; I have tried this on both a C Drive install and my Windows shared network install with the same results.</P>
<P mce_keep="true">&nbsp;</P>
<P>Any help would be appreciated.</P>
<P>
Best Regards,</P>
<P>Stephen Kovacsiss</P>
<P>[/quote]</P>
<P>I had this problem also when setting up Plato which, I think, is essentially the same thing you're trying to do.&nbsp; The only way the quote feature worked without hanging was to&nbsp;use the&nbsp;quote only in plain content.&nbsp; If&nbsp;I tried to add the quote in formatted content with the "add varient at message creation" box checked, pmail would hang as soon as I opened a new message.</P>
