Most likely you have a wiring problem (as the only change was replace a switch) in your building, with intermittent connection problems. This will affect software protocols that are poor in recovering from faults, like paradox databases and open imap connections. The only way to catch something like this, is to investigate piece by piece what is happening in each segment of your network.
Edit add: I should have said also, that with Vista you need to open explorer, and make sure explorer reconnects the drive, before you attempt to restart Pegasus Mail.
<P>Most likely you have a wiring problem (as the only change was&nbsp;replace a switch)&nbsp;in your building, with intermittent connection problems. This will affect software protocols that are poor in recovering from faults, like paradox databases and open imap connections. The only way to catch something like this, is to investigate piece by piece what is happening in each segment of your network.</P>
<P>Edit add: I should have said also, that with Vista you need to open explorer, and make sure explorer reconnects the drive, before you attempt to restart Pegasus Mail.</P>
