Problems for others replying to my Pegasus e-mails
It seems that when others get an e-mail from me and try to use the 'reply' feature, their e-mail programs (usually Outlook) show an error in sending the reply. They usually end up sending their reply as a new e-mail. Is this a problem with my settings? Any help welcome.
<P>Hi,</P> <P>It seems that when others get an e-mail from me and try to use the 'reply' feature, their e-mail programs (usually Outlook) show an error in sending the reply. They usually end up sending their reply as a new e-mail. Is this a problem with my settings? Any help welcome.</P> <P>Thanks</P>
Probably, hard to tell without seeing one of you messages.  Check to make sure that you have a valid SMTP address in Tools | Options | Sending mail | Default "reply to:" address.  If this is empty then the reply usually goes to the From: address as specified in Tools | Internet options | General.  You can send a message to techsupp@tstephenson.com and I can check if the addresses are correct.
<blockquote>It seems that when others get an e-mail from me and try to use the 'reply' feature, their e-mail programs (usually Outlook) show an error in sending the reply. They usually end up sending their reply as a new e-mail. Is this a problem with my settings?</blockquote>Probably, hard to tell without seeing one of you messages.  Check to make sure that you have a valid SMTP address in Tools | Options | Sending mail | Default "reply to:" address.  If this is empty then the reply usually goes to the From: address as specified in Tools | Internet options | General.  You can send a message to <a href="mailto:techsupp@tstephenson.com" title="mailto:techsupp@tstephenson.com" mce_href="mailto:techsupp@tstephenson.com">techsupp@tstephenson.com</a> and I can check if the addresses are correct.
