Need help setting MX records
I am using the same IP for my http server and Mercury 32 mail server.
However, I am using comcast's smtp to relay the mail (smtp.comcast.net,
port 587) if that even matters for the MX.
It does not matter how you are sending.  A MX record is not really required, the RFC says to send to the A record if there is no MX record.  That said, there are some strange mail servers out there and so I would recommend that you enter the GoDaddy domain as the MX record domain so those that require a MX record will be happy.  Now if you do have an off-site MX host for your domain then you should also enter this MX host as a higher numbers secondary MX host.
FWIW, it would have been very helpful if you had not munged up the real data so we could provide real answers.  This is not a security issue, these data go out with every message you send.
<blockquote>I am using the same IP for my http server and Mercury 32 mail server. However, I am using comcast's smtp to relay the mail (smtp.comcast.net, port 587) if that even matters for the MX.</blockquote><p>It does not matter how you are sending.  A MX record is not really required, the RFC says to send to the A record if there is no MX record.  That said, there are some strange mail servers out there and so I would recommend that you enter the GoDaddy domain as the MX record domain so those that require a MX record will be happy.  Now if you do have an off-site MX host for your domain then you should also enter this MX host as a higher numbers secondary MX host.</p><p>FWIW, it would have been very helpful if you had not munged up the real data so we could provide real answers.  This is not a security issue, these data go out with every message you send. </p><p> </p>
Hello everyone,
 I am new to running a mail server, so I do not know how to set MX records for my domain name. I know how to physically change them, I just don't know what to put in as the host or goes to.
Here are my records for my godaddy domain:
http://i94.photobucket.com/albums/l81/buyfromme3/mxhelp.png
 Thanks in advance,
Nick
<p>Hello everyone,</p><p> I am new to running a mail server, so I do not know how to set MX records for my domain name. I know how to physically change them, I just don't know what to put in as the host or goes to.</p><p>Here are my records for my godaddy domain: </p><p>http://i94.photobucket.com/albums/l81/buyfromme3/mxhelp.png</p><p> I am using the same IP for my http server and Mercury 32 mail server. However, I am using comcast's smtp to relay the mail (smtp.comcast.net, port 587) if that even matters for the MX. </p><p> Thanks in advance, </p><p>Nick </p>
