Sv: Stability problems solved
I have had some stability problems in the past and i was always refered to a bad disk or AV which wasn't the cause. Out of frustration i installed the 4.71beta and boom everything is now working flawlessly,
<p>I have had some stability problems in the past and i was always refered to a bad disk or AV which wasn't the cause. Out of frustration i installed the 4.71beta and boom everything is now working flawlessly,  </p>
