Dear Sirs,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Please help us solve the problem. We have installed Novell 6.5, Mercuri 1.48. NDS mode. And we have a problem. We cannot make postmaster receive messages about errors. For example, if mail comes to a user who is not registered in Novell, Mercury sends an answer to the author of the message about the error, but postmaster doesn’t get a message about it. This is my Mercury.ini
# MERCURY.INI generated by Mercury Setup
# Sample MERCURY.INI file for Mercury in NetWare 4.1 NDS mode.
# This version of the file implements most of the possible
# switches for each module, but you can edit it to do less if
# you wish. All the fields shown below are described in the
# file MGUIDE.EXE which is supplied in the Mercury archive.
# Anything after a '#' to the end of the line is a comment and
# is stripped out before parsing. Trailing and leading whitespace
# is also stripped before parsing.
[General]
myname: ukrnew.gov.ua # Canonical name for this server
timezone: +0200 # Time Zone to add to date fields
mailqueue: MAILN/SYS:SMTPMAIL # Where mail should be put for delivery
smtpqueue: MAILN/SYS:SMTPMAIL # Where the SMTP client should look for mail
# note: smtpqueue and mailqueue can be the same
[Mercury]
failfile: MAILN/SYS:SYSTEM/MERCURY/FAILURE.MER # Delivery failure notification template
confirmfile: MAILN/SYS:SYSTEM/MERCURY/CONFIRM.MER # Delivery confirmation template
aliasfile: MAILN/SYS:SYSTEM/MERCURY/ALIAS.MER # System-wide alias file
synfile: MAILN/SYS:SYSTEM/MERCURY/SYNONYM.MER # User synonym database
listfile: MAILN/SYS:SYSTEM/MERCURY/LISTS.MER # List of lists
logfile: MAILN/SYS:SYSTEM/MERCURY/MERCURY.LOG # Traffic logging file
bitnethost: cunyvm.cuny.edu # Relay host for ".bitnet" rewrites
poll: 10 # Seconds between queue polling cycles
scratch: MAILN/SYS:SYSTEM/MERCURY # Where we can write temp files
switch: 2 # number of ms to yield per op on heavy I/O
postmaster: pm.ugen # NetWare UIC of postmaster
broadcast: 1 # Yes, we want broadcast notifications, but
PM_notify: 1 # Do/Don't send errors to the postmaster
change_owner: 1 # Change message ownership to recipient
automaintenance : 1
ldap_synonyms : 1
decode_rfc1522 : 1 # Decode RFC1522-encoded strings in broadcasts
requeue_interval : 60 # Number of minutes between delivery retries
max_retries : 48 # Maximum number of delivery retry attempts
# noticeboards: MAILN/SYS:PUBLIC/NB # Where to find Pegasus Mail noticeboards
# NDS_Reauthenticate : 1 # Work around NDS connection loss problems
# gullible : 1 # Do not perform strict address validation
# NetWare 4.x/5.x NDS mode user information
# The [NDS] Section of MERCURY.INI is only used in NetWare NDS mode. It
# can be omitted in many cases, since Mercury will prompt for the values
# set in the section if they are absent.
# Under NetWare 4.x and later, Mercury has to login to Directory Services
# as a user object. The account Mercury uses must have sufficient privilege
# to perform the following tasks:
# * Scan, Create, Read, Rename and Delete files in every
# user's new mailbox directory
# * Read the "home directory" attribute for every mail user
# to which it might be called upon to deliver mail
# * Search the NDS tree (i.e, have Browse and Read rights) in
# all contexts in which it might operate
# * Read all members of any group to which it may be called
# upon to deliver mail
# * If running in automaintenance mode, it must be able to add
# and delete NDS attributes for any user to which it may
# deliver mail, and create and delete ACLs on any mail user's
# "home directory" NDS attribute.
# If you omit the "password" field, Mercury will prompt for it at
# startup time.
# Note that you must enter the Mercury User ID as an NDS name expressed
# RELATIVE TO THE ROOT OF YOUR NDS TREE - there is no default context.
# Two other options affecting NDS-mode operation are also available in
# other sections of MERCURY.INI:
# In the [General] Section:
# "Mailbox_Mode", value 0 or 1, default 0. If 0, Mercury will use the
# new mailbox directory structure created by MAKEMBOX and PMUSER. If
# 1, Mercury will assume that you have loaded the NetWare 4.1 MHS
# Services product and will deliver to the mailbox structure created
# by that system. NOTE: this does NOT mean that Mercury will act as
# an MHS<-->SMTP gateway - it will NOT. It simply controls where it
# will place incoming mail.
# In the [Mercury] section:
# "Automaintenance", value 1 or 0: if non-zero, Mercury will automatically
# create new mail directories for users when it detects that they need
# them, using the same logic as the PMUSER NLM. If 0, sending mail to
# a user with no new mail directory currently created will result in
# an error.
# [NDS]
# UserID : Admin.pmail
# Password : xxxx
[MercuryC]
host: 10.95.1.10 # mail mail host which relays for us
poll: 30 # Seconds between queue polling cycles
failfile: MAILN/SYS:SYSTEM/MERCURY/FAILURE.MER # Delivery failure template
max_retries: 72 # Maximum number of delivery retry attempts
esmtp: 1 # Yes, we want to use ESMTP extensions
# session_logging : SYS:SYSTEM/MERCURY/LOG
[MercuryS]
switch: 2
debug: 1 # Whether or not to show session progress
relay: 0 # We do not permit non-local mail relaying
# strict_relay: 1 # Turns on strict relaying controls
# allow: xxx.xxx.xxx.2 # A machine we WILL permit to connect
# refuse: xxx.xxx.xxx.0 # A group of machines we WON'T permit.
# logfile: MAILN/SYS:SYSTEM/MERCURY/MERCURYS.LOG
# size: 1500000 # Maximum message size to accept
# killfile: SYS:SYSTEM/MERCURY/MERCURYS.KFL # Never accept mail from here
# smtp_auth: 1 # Turn on authenticated SMTP support
# auth_file: sys:system/mercury/auth.mer # Username/Password file for AUTH
[MercuryP]
scratch : MAILN/SYS:SYSTEM/MERCURY
switch : 2
timeout : 180
# logfile : MAILN/SYS:SYSTEM/MERCURY/MERCURYP.LOG
# Using NetWare Groups: Mercury can deliver to NetWare Groups on your
# file server, but will only do so for groups that are defined in the
# "[Groups]" section. To enable a group for mail delivery, place its
# Internet name on the left-hand side of a [Groups] entry and the full
# NDS name of the group relative to the root of the NDS tree on the
# right-hand side.
# [Groups]
# testgroup : Test_group.pmail
# Defining domains for NetWare 4.1:
# Mercury can service an unlimited number of NDS contexts on your
# network, provided the NDS usercode you provide it with has sufficient
# privilege to be able to access all mail users in those contexts. Each
# context may have its own domain name, and it is possible to have a
# domain name which applies to all organizational units in and below a
# given context.
# The [Domains] syntax for NetWare 4.1 is simply an NDS context on the
# left hand side, and the domain name by which it is known to Internet
# hosts on the right hand side. You may have multiple domain names for
# the same context, but at this stage you may not have multiple contexts
# with a single domain name. If you want a domain definition to apply
# to all organizational units (contexts) below the specified context as
# well as that context, prefix the context name with a '/' character -
# so the entry:
# /dev.pmail : dev.pmail.gen.nz
# indicates that the Internet domain "dev.pmail.gen.nz" applies to the
# context "dev.pmail", and to any context below it in the NDS tree.
[Domains]
# Context Domain name
/[Root] : ukr.gov.ua
[Maiser]
Maiser : Maiser
Helpfile : MAILN/SYS:SYSTEM/MERCURY/MAISER.HLP
Lookupfile : MAILN/SYS:SYSTEM/MERCURY/MAISER.LKP
Send_dir : MAILN/SYS:SYSTEM/MERCURY/SENDABLE
Logfile : MAILN/SYS:SYSTEM/MERCURY/MAISER.LOG
Notify : MAILN/SYS:SYSTEM/MERCURY/TMP
Local_only : Y
# The following section contains settings for the Mercury PH server,
# MERCURYH.NLM. The principal item in this section is the "Addressbook"
# keyword, which should reference the .PMR file of the Pegasus Mail
# addressbook from which MercuryH should service requests.
[MercuryH]
# addressbook : sys:system/mercury/ph.pmr
Administrator : postmaster@ukrnew.gov.ua
Port : 105
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="mso-ansi-language: EN-US"><FONT size=3><FONT face="Times New Roman">Dear Sirs,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></FONT></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-ansi-language: EN-US">Please help us solve the problem. We have installed Novell 6.5, Mercuri 1.48.<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN></SPAN><SPAN lang=EN-GB style="mso-ansi-language: EN-GB">NDS</SPAN><SPAN lang=EN-GB style="mso-ansi-language: EN-US"> </SPAN><SPAN lang=EN-GB style="mso-ansi-language: EN-GB">mode</SPAN><SPAN lang=EN-US style="mso-ansi-language: EN-US">. And we have a problem. We cannot make postmaster receive messages about errors. For example, if mail comes to a user who is not registered in Novell, Mercury<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>sends an answer to the author of the message about the error, but postmaster doesn’t get a message about it. This is my Mercury.ini</SPAN></FONT></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-ansi-language: EN-US"></SPAN></FONT></FONT>&nbsp;</P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT face="Times New Roman"><SPAN lang=EN-US style="mso-ansi-language: EN-US"></SPAN></FONT></FONT><SPAN lang=UK style="mso-ansi-language: UK"><o:p>#&nbsp; MERCURY.INI generated by Mercury Setup
#&nbsp; Sample MERCURY.INI file for Mercury in NetWare 4.1 NDS mode.
#&nbsp; This version of the file implements most of the possible
#&nbsp; switches for each module, but you can edit it to do less if
#&nbsp; you wish. All the fields shown below are described in the
#&nbsp; file MGUIDE.EXE which is supplied in the Mercury archive.
#&nbsp; Anything after a '#' to the end of the line is a comment and
#&nbsp; is stripped out before parsing. Trailing and leading whitespace
#&nbsp; is also stripped before parsing.
#</o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=UK style="mso-ansi-language: UK"><o:p>[General]
myname:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ukrnew.gov.ua&nbsp;&nbsp; # Canonical name for this server
timezone:&nbsp;&nbsp;&nbsp; +0200&nbsp;&nbsp; # Time Zone to add to date fields
file_api:&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Use the file api instead of queues
mailqueue:&nbsp;&nbsp; MAILN/SYS:SMTPMAIL&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Where mail should be put for delivery
smtpqueue:&nbsp;&nbsp; MAILN/SYS:SMTPMAIL&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Where the SMTP client should look for mail
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # note: smtpqueue and mailqueue can be the same</o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=UK style="mso-ansi-language: UK"><o:p>[Mercury]
failfile:&nbsp;&nbsp;&nbsp;&nbsp; MAILN/SYS:SYSTEM/MERCURY/FAILURE.MER&nbsp; # Delivery failure notification template
confirmfile:&nbsp; MAILN/SYS:SYSTEM/MERCURY/CONFIRM.MER&nbsp; # Delivery confirmation template
aliasfile:&nbsp;&nbsp;&nbsp; MAILN/SYS:SYSTEM/MERCURY/ALIAS.MER&nbsp;&nbsp;&nbsp; # System-wide alias file
synfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; MAILN/SYS:SYSTEM/MERCURY/SYNONYM.MER&nbsp; # User synonym database
listfile:&nbsp;&nbsp;&nbsp;&nbsp; MAILN/SYS:SYSTEM/MERCURY/LISTS.MER&nbsp;&nbsp;&nbsp; # List of lists
logfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; MAILN/SYS:SYSTEM/MERCURY/MERCURY.LOG&nbsp; # Traffic logging file
bitnethost:&nbsp;&nbsp; cunyvm.cuny.edu&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Relay host for ".bitnet" rewrites
poll:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 10&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Seconds between queue polling cycles
scratch:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; MAILN/SYS:SYSTEM/MERCURY&nbsp;&nbsp; # Where we can write temp files
switch:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # number of ms to yield per op on heavy I/O
returnlines:&nbsp; 15&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # How many lines of failed messages to return
postmaster:&nbsp;&nbsp; pm.ugen&nbsp;&nbsp;&nbsp;&nbsp; # NetWare UIC of postmaster
broadcast:&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Yes, we want broadcast notifications, but
receipts:&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # ... no broadcasts for receipt confirmations
PM_notify:&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Do/Don't send errors to the postmaster
change_owner: 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Change message ownership to recipient
automaintenance : 1
ldap_synonyms : 1
decode_rfc1522 : 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Decode RFC1522-encoded strings in broadcasts
requeue_interval : 60&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Number of minutes between delivery retries
max_retries : 48&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Maximum number of delivery retry attempts
# noticeboards: MAILN/SYS:PUBLIC/NB&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Where to find Pegasus Mail noticeboards
# NDS_Reauthenticate : 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Work around NDS connection loss problems
# gullible : 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Do not perform strict address validation</o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=UK style="mso-ansi-language: UK"><o:p>#&nbsp; NetWare 4.x/5.x NDS mode user information
#&nbsp; The [NDS] Section of MERCURY.INI is only used in NetWare NDS mode. It
#&nbsp; can be omitted in many cases, since Mercury will prompt for the values
#&nbsp; set in the section if they are absent.
#&nbsp; Under NetWare 4.x and later, Mercury has to login to Directory Services
#&nbsp; as a user object. The account Mercury uses must have sufficient privilege
#&nbsp; to perform the following tasks:
#&nbsp;&nbsp;&nbsp;&nbsp; * Scan, Create, Read, Rename and Delete files in every
#&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; user's new mailbox directory
#&nbsp;&nbsp;&nbsp;&nbsp; * Read the "home directory" attribute for every mail user
#&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; to which it might be called upon to deliver mail
#&nbsp;&nbsp;&nbsp;&nbsp; * Search the NDS tree (i.e, have Browse and Read rights) in
#&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; all contexts in which it might operate
#&nbsp;&nbsp;&nbsp;&nbsp; * Read all members of any group to which it may be called
#&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; upon to deliver mail
#&nbsp;&nbsp;&nbsp;&nbsp; * If running in automaintenance mode, it must be able to add
#&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; and delete NDS attributes for any user to which it may
#&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; deliver mail, and create and delete ACLs on any mail user's
#&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; "home directory" NDS attribute.
#&nbsp; If you omit the "password" field, Mercury will prompt for it at
#&nbsp; startup time.
#&nbsp; Note that you must enter the Mercury User ID as an NDS name expressed
#&nbsp; RELATIVE TO THE ROOT OF YOUR NDS TREE - there is no default context.
#&nbsp; Two other options affecting NDS-mode operation are also available in
#&nbsp; other sections of MERCURY.INI:
#&nbsp; In the [General] Section:
#&nbsp; "Mailbox_Mode", value 0 or 1, default 0. If 0, Mercury will use the
#&nbsp;&nbsp;&nbsp;&nbsp; new mailbox directory structure created by MAKEMBOX and PMUSER. If
#&nbsp;&nbsp;&nbsp;&nbsp; 1, Mercury will assume that you have loaded the NetWare 4.1 MHS
#&nbsp;&nbsp;&nbsp;&nbsp; Services product and will deliver to the mailbox structure created
#&nbsp;&nbsp;&nbsp;&nbsp; by that system. NOTE: this does NOT mean that Mercury will act as
#&nbsp;&nbsp;&nbsp;&nbsp; an MHS&lt;--&gt;SMTP gateway - it will NOT. It simply controls where it
#&nbsp;&nbsp;&nbsp;&nbsp; will place incoming mail.
#&nbsp; In the [Mercury] section:
#&nbsp; "Automaintenance", value 1 or 0: if non-zero, Mercury will automatically
#&nbsp;&nbsp;&nbsp;&nbsp; create new mail directories for users when it detects that they need
#&nbsp;&nbsp;&nbsp;&nbsp; them, using the same logic as the PMUSER NLM. If 0, sending mail to
#&nbsp;&nbsp;&nbsp;&nbsp; a user with no new mail directory currently created will result in
#&nbsp;&nbsp;&nbsp;&nbsp; an error.</o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=UK style="mso-ansi-language: UK"><o:p># [NDS]
# UserID&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp; Admin.pmail
# Password : xxxx</o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=UK style="mso-ansi-language: UK"><o:p>[MercuryC]
host:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 10.95.1.10&nbsp;&nbsp;&nbsp;&nbsp; # mail mail host which relays for us
scratch:&nbsp;&nbsp;&nbsp;&nbsp; MAILN/SYS:SYSTEM/MERCURY&nbsp;&nbsp; # Where we can write temp files
poll:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 30&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Seconds between queue polling cycles
switch:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # number of ms to yield per op on heavy I/O
returnlines: 15&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # How many lines of failed messages to return
failfile:&nbsp;&nbsp;&nbsp; MAILN/SYS:SYSTEM/MERCURY/FAILURE.MER&nbsp; # Delivery failure template
max_retries: 72&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Maximum number of delivery retry attempts
esmtp:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Yes, we want to use ESMTP extensions
# session_logging : SYS:SYSTEM/MERCURY/LOG</o:p></SPAN></P><SPAN lang=UK style="mso-ansi-language: UK"><o:p>
[MercuryS]
debug:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Whether or not to show session progress
relay:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # We do not permit non-local mail relaying
# strict_relay: 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Turns on strict relaying controls
# allow:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xxx.xxx.xxx.2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # A machine we WILL permit to connect
# refuse:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xxx.xxx.xxx.0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # A group of machines we WON'T permit.
# logfile:&nbsp;&nbsp;&nbsp;&nbsp; MAILN/SYS:SYSTEM/MERCURY/MERCURYS.LOG
# size:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 1500000&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Maximum message size to accept
# killfile:&nbsp;&nbsp;&nbsp;&nbsp; SYS:SYSTEM/MERCURY/MERCURYS.KFL&nbsp; # Never accept mail from here
# smtp_auth:&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Turn on authenticated SMTP support
# auth_file:&nbsp;&nbsp;&nbsp; sys:system/mercury/auth.mer&nbsp; # Username/Password file for AUTH</P>
[MercuryP]
scratch&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; MAILN/SYS:SYSTEM/MERCURY
switch&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; 2
timeout&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; 180
# logfile&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; MAILN/SYS:SYSTEM/MERCURY/MERCURYP.LOG
# refuse:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xxx.xxx.xxx.0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # A group of machines we WON'T permit.</P>
#&nbsp; Using NetWare Groups: Mercury can deliver to NetWare Groups on your
#&nbsp; file server, but will only do so for groups that are defined in the
#&nbsp; "[Groups]" section. To enable a group for mail delivery, place its
#&nbsp; Internet name on the left-hand side of a [Groups] entry and the full
#&nbsp; NDS name of the group relative to the root of the NDS tree on the
#&nbsp; right-hand side.</P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"># [Groups]
# testgroup&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; Test_group.pmail</P>
#&nbsp; Defining domains for NetWare 4.1:
#&nbsp; Mercury can service an unlimited number of NDS contexts on your
#&nbsp; network, provided the NDS usercode you provide it with has sufficient
#&nbsp; privilege to be able to access all mail users in those contexts. Each
#&nbsp; context may have its own domain name, and it is possible to have a
#&nbsp; domain name which applies to all organizational units in and below a
#&nbsp; given context.
#&nbsp; The [Domains] syntax for NetWare 4.1 is simply an NDS context on the
#&nbsp; left hand side, and the domain name by which it is known to Internet
#&nbsp; hosts on the right hand side. You may have multiple domain names for
#&nbsp; the same context, but at this stage you may not have multiple contexts
#&nbsp; with a single domain name. If you want a domain definition to apply
#&nbsp; to all organizational units (contexts) below the specified context as
#&nbsp; well as that context, prefix the context name with a '/' character -
#&nbsp; so the entry:
#&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; /dev.pmail&nbsp; : dev.pmail.gen.nz
#&nbsp; indicates that the Internet domain "dev.pmail.gen.nz" applies to the
#&nbsp; context "dev.pmail", and to any context below it in the NDS tree.</P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt">[Domains]
# Context&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Domain name
/[Root]&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; ukr.gov.ua</P>
[Maiser]
Maiser&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; Maiser
Helpfile&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; MAILN/SYS:SYSTEM/MERCURY/MAISER.HLP
Lookupfile&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; MAILN/SYS:SYSTEM/MERCURY/MAISER.LKP
Send_dir&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; MAILN/SYS:SYSTEM/MERCURY/SENDABLE
Logfile&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; MAILN/SYS:SYSTEM/MERCURY/MAISER.LOG
Notify&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; MAILN/SYS:SYSTEM/MERCURY/TMP
Local_only&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; Y</P>
# addressbook from which MercuryH should service requests.</P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt">[MercuryH]
# addressbook&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; sys:system/mercury/ph.pmr
Administrator&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; <A href="mailto:postmaster@ukrnew.gov.ua" mce_href="mailto:postmaster@gesn.kv.energy.cov.ua">postmaster@ukrnew.gov.ua</A>
Port&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; 105
</o:p></SPAN></P>
