>>I would have though the router configuration would have shown the external interface and not the internal.
You asked for the external interface. But i have no idea how to get hold of that information. All i can access on the router is the page i just posted, with all options clicked on.
If you are only getting an IP address via DCHP then this is a dynamic address and you cannot use MercuryE with a dynamically assigned IP address. You need to switch to using MercuryC and enter the host name of your ISP's SMTP host as the relay host name.
<blockquote><p>&gt;&gt;I would have though the router configuration would have shown the external interface and not the internal.</p><p> You asked for the external interface. But i have no idea how to get hold of that information. All i can access on the router is the page i just posted, with all options clicked on. </p></blockquote><p>If you are only getting an IP address via DCHP then this is a dynamic address and you cannot use MercuryE with a dynamically assigned IP address.&nbsp; You need to switch to using MercuryC and enter the host name of your ISP's SMTP host as the relay host name.
