Ok i have tried to do all that stuff and now i get the error "SMTP server response: 553 We do not relay non-local mail, sorry" when i run my php file. I am attaching a screen of my zoneedit stuff maybe that can help in some way, also i am including my .ini again in hopes that i can still resolve this.
# MERCURY.INI generated by Mercury Setup
# Sample Bindery Mode MERCURY.INI file (in fact, the one I use on
# my production server). This one implements most of the possible
# switches for each module, but you can edit it to do less if you
# wish. All the fields shown below are described in the file
# MGUIDE.HLP which is supplied in the Mercury archive.
# Anything after a '#' to the end of the line is a comment and
# is stripped out before parsing. Trailing and leading whitespace
# is also stripped before parsing. Many sample commands have been
# left in this file commented out for reference purposes.
[General]
myname: homickshouse.com # Canonical name for this server
timezone: +0000 # Time Zone to add to date fields
mailqueue: C:\XAMPP\MERCURYMAIL\QUEUE # Where mail should be put for delivery
smtpqueue: C:\XAMPP\MERCURYMAIL\QUEUE # Where the SMTP client should look for mail
newmail_path: C:\XAMPP\MERCURYMAIL\MAIL\~N # Where to find the users' WinPMail mailboxes.
[Protocols]
MERCURYS.DLL
MERCURYP.DLL
MERCURYE.DLL
# MERCURYC.DLL
MERCURYD.DLL
# MERCURYH.DLL
# MERCURYF.DLL
# MERCURYW.DLL
# MERCURYX.DLL
# MERCURYI.DLL
# MERCURYB.DLL
[Mercury]
failfile: C:\xampp\MERCURYMAIL\Mercury\FAILURE.MER # Delivery failure notification template
confirmfile: C:\xampp\MERCURYMAIL\Mercury\CONFIRM.MER # Delivery confirmation template
aliasfile: C:\xampp\MERCURYMAIL\Mercury\ALIAS.MER # System-wide alias file
synfile: C:\xampp\MERCURYMAIL\Mercury\SYNONYM.MER # User synonym database
listfile: C:\xampp\MERCURYMAIL\Mercury\LISTS.MER # List of lists
retpath: 1 # Do/Don't use 'return-path' for errors
bitnethost: cunyvm.cuny.edu # Relay host for '.bitnet' rewrites
poll: 10 # Seconds between queue polling cycles
scratch: C:\xampp\MERCURYMAIL\Scratch # Where we can write temp files
postmaster: Admin # NetWare UIC of postmaster
broadcast: 1 # Yes, we want broadcast notifications, but
PM_notify: 1 # Do/Don't send errors to the postmaster
change_owner: 1 # Change message ownership to recipient
RetryPeriod: 30 # Period between job retries (minutes)
MaxRetries: 16 # Maximum number of times a job can fail
TwoPasses: 1 # If NZ, process submission queue in 2 passes
Autoaddress: 0 # If NZ, auto-generate user addresses based on name
Daily_exit: 0 # If NZ, auto-restart each day after maintenance
Alt_Forward: 0 # If NZ, allow alternate forwarding specification
Maint_hour: 2 # Hour for daily maintenance (24-hour clock)
Retry_Mode: 0 # If NZ, use progressive backoff for queue retries
Local_DSNs: 1 # If NZ generate Delivery Status for local users only
DSN_time1: 10800 # Seconds deferred before first DSN is sent
DSN_time2: 86400 # Seconds deferred before second DSN is sent
DSN_time3: 259200 # Seconds deferred before third DSN is sent
Host_in_title: 0 # If NZ, show hostname in system tray and taskbar
[MercuryC]
# Session_logging: G:\ # Directory to write session transcripts
host: # mail mail host which relays for us
scratch: C:\xampp\MERCURYMAIL\Mercury # Where we can write temp files
poll: 30 # Seconds between queue polling cycles
failfile: C:\xampp\MERCURYMAIL\Mercury\FAILURE.MER # Delivery failure template
esmtp: 1 # Yes, we want to use ESMTP extensions
[MercuryE]
Poll : 15
Timeout : 60
Log_Verbose : 0
DNS_Timeout : 20
DNS_Retries : 4
Transcripts : 1
MaxThreads : 10
[MercuryD]
scratch : C:\xampp\MERCURYMAIL\Mercury
# Timeout : 30
# Poll : 120 # How often to check hosts for new mail (seconds)
[MercuryS]
Debug : 1
Logfile : C:\xampp\MERCURYMAIL\Logs\MERCURYS.LOG
Timeout : 30
Relay : 0
Strict_Relay : 1
Allow_Illegals : 0
SMTP_Authentication : 0
Compliance_Settings : 0
Maximum_Failed_Rcpts : 4
Max_Relay_Attempts : 4
SSL_Mode : 0
ST_Blacklisting : 288
No_VRFY : 0
SMTP_ConnFlags : 0
[MercuryP]
Scratch : C:\xampp\MERCURYMAIL\Mercury
Stack : 32768
Mark_Read : 1
SSL_Mode : 0
Login_Disabled : 0
UIDL_nul_list : 1
Timeout : 60
[MercuryX]
# Cmd_Delay: 10
# Cmd_Wait: 1
# IE4_Dialling: 0
# Use_ETRN: 1
# Clients_only: 1
# [Groups]
# testgroup : TESTGRP
[Domains]
mail: bobbylaptop
mail: homickshouse.com
mail: mail.homickshouse.com
mail: 67.186.21.74
mail: 192.168.2.2
[Maiser]
Helpfile: C:\xampp\MERCURYMAIL\Mercury\MAISER.HLP # Help sent on failed maiser requests
Lookupfile: C:\xampp\MERCURYMAIL\Mercury\MAISER.LKP # Format file for the 'lookup' command
Send_dir: C:\xampp\MERCURYMAIL\Mercury\SENDABLE # Directory for the 'send' command
Logfile: C:\xampp\MERCURYMAIL\Logs\MAISER.LOG # Mail server log file
Notify: C:\xampp\MERCURYMAIL\Mercury\TMP # Dir. for pending 'notify' commands
[MercuryH]
Logfile : C:\xampp\MERCURYMAIL\Logs\MERCURYH.LOG
Timeout : 30
[MercuryI]
Scratch : C:\xampp\MERCURYMAIL\SCRATCH
Timeout : 120
Server_Port : 143
Idle_Timeout : 1800
SSL_Mode : 0
Login_Disabled : 0
[MercuryB]
# Logfile : o:\mail\tmp\mercuryb.log
Timeout : 120
Server_Port : 2224
# Session_logging : o:\mail\mercury\mblogs
# Session_logmode : 0
Idle_Timeout : 1800
[Groups]
[Rewrite]
[Statistics]
StatFlags: 0 # Statistical reporting settings
STM_Hours: 24 # How often to e-mail stat log files
Thanks again for spending the time to try to help me on this, i'm sorry that i'm not real intune to the mail server, this is only my first time trying to do this. If there is any other information that you need that i haven't provided that will help out please let me know and i'll try to provide it. Thanks again guys
<p>Ok i have tried to do all that stuff and now i get the error "SMTP server response: 553 We do not relay non-local mail, sorry" when i run my php file. I am attaching a screen of my zoneedit stuff maybe that can help in some way, also i am including my .ini again in hopes that i can still resolve this.</p><p>&nbsp;</p><p>
</p><p>&nbsp;#&nbsp; MERCURY.INI generated by Mercury Setup
#&nbsp; Sample Bindery Mode MERCURY.INI file (in fact, the one I use on
#&nbsp; my production server). This one implements most of the possible
#&nbsp; switches for each module, but you can edit it to do less if you
#&nbsp; wish. All the fields shown below are described in the file
#&nbsp; MGUIDE.HLP which is supplied in the Mercury archive.
#&nbsp; Anything after a '#' to the end of the line is a comment and
#&nbsp; is stripped out before parsing. Trailing and leading whitespace
#&nbsp; is also stripped before parsing. Many sample commands have been
#&nbsp; left in this file commented out for reference purposes.
[General]
myname:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; homickshouse.com&nbsp;&nbsp;&nbsp; # Canonical name for this server
timezone:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; +0000&nbsp;&nbsp;&nbsp; # Time Zone to add to date fields
file_api:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # Use the file api instead of queues
mailqueue:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\XAMPP\MERCURYMAIL\QUEUE&nbsp;&nbsp;&nbsp; # Where mail should be put for delivery
smtpqueue:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\XAMPP\MERCURYMAIL\QUEUE&nbsp;&nbsp;&nbsp; # Where the SMTP client should look for mail
newmail_path:&nbsp;&nbsp;&nbsp; C:\XAMPP\MERCURYMAIL\MAIL\~N&nbsp;&nbsp;&nbsp; # Where to find the users' WinPMail mailboxes.
[Protocols]
MERCURYS.DLL
MERCURYP.DLL
MERCURYE.DLL
# MERCURYC.DLL
MERCURYD.DLL
# MERCURYH.DLL
# MERCURYF.DLL
# MERCURYW.DLL
# MERCURYX.DLL
# MERCURYI.DLL
# MERCURYB.DLL
[Mercury]
failfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\xampp\MERCURYMAIL\Mercury\FAILURE.MER&nbsp;&nbsp;&nbsp; # Delivery failure notification template
confirmfile:&nbsp;&nbsp; C:\xampp\MERCURYMAIL\Mercury\CONFIRM.MER&nbsp;&nbsp;&nbsp; # Delivery confirmation template
aliasfile:&nbsp;&nbsp;&nbsp;&nbsp; C:\xampp\MERCURYMAIL\Mercury\ALIAS.MER&nbsp;&nbsp;&nbsp; # System-wide alias file
synfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\xampp\MERCURYMAIL\Mercury\SYNONYM.MER&nbsp;&nbsp;&nbsp; # User synonym database
listfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\xampp\MERCURYMAIL\Mercury\LISTS.MER&nbsp;&nbsp;&nbsp; # List of lists
logwidth:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 30&nbsp;&nbsp;&nbsp; # Width of address fields in logfile
retpath:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # Do/Don't use 'return-path' for errors
maxhops:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 30&nbsp;&nbsp;&nbsp; # Used to detect mailing loops
gullible:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, don't validate 'From' fields
bitnethost:&nbsp;&nbsp;&nbsp; cunyvm.cuny.edu&nbsp;&nbsp;&nbsp; # Relay host for '.bitnet' rewrites
poll:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 10&nbsp;&nbsp; # Seconds between queue polling cycles
scratch:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\xampp\MERCURYMAIL\Scratch&nbsp;&nbsp;&nbsp; # Where we can write temp files
returnlines:&nbsp;&nbsp; 15&nbsp;&nbsp;&nbsp; # How many lines of failed messages to return
postmaster:&nbsp;&nbsp;&nbsp; Admin&nbsp;&nbsp;&nbsp; # NetWare UIC of postmaster
broadcast:&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # Yes, we want broadcast notifications, but
receipts:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # ... no broadcasts for receipt confirmations
PM_notify:&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # Do/Don't send errors to the postmaster
change_owner:&nbsp; 1&nbsp;&nbsp;&nbsp; # Change message ownership to recipient
auto_tzone:&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # If NZ, obtain timezone information from OS
LogLevel:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 15&nbsp;&nbsp;&nbsp; # System message reporting level
LogMax:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 100&nbsp;&nbsp;&nbsp; # Maximum number of system messages to store
RetryPeriod:&nbsp;&nbsp; 30&nbsp;&nbsp;&nbsp; # Period between job retries (minutes)
MaxRetries:&nbsp;&nbsp;&nbsp; 16&nbsp;&nbsp;&nbsp; # Maximum number of times a job can fail
TwoPasses:&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # If NZ, process submission queue in 2 passes
Autoaddress:&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, auto-generate user addresses based on name
Daily_exit:&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, auto-restart each day after maintenance
No_Areply:&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, disable automatic replies system-wide
Alt_Forward:&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, allow alternate forwarding specification
Maint_hour:&nbsp;&nbsp;&nbsp; 2&nbsp;&nbsp;&nbsp; # Hour for daily maintenance (24-hour clock)
Maint_min:&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # Minute for daily maintenance
Retry_Mode:&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, use progressive backoff for queue retries
Local_DSNs:&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # If NZ generate Delivery Status for local users only
DSN_time1:&nbsp;&nbsp;&nbsp;&nbsp; 10800&nbsp;&nbsp;&nbsp; # Seconds deferred before first DSN is sent
DSN_time2:&nbsp;&nbsp;&nbsp;&nbsp; 86400&nbsp;&nbsp;&nbsp; # Seconds deferred before second DSN is sent
DSN_time3:&nbsp;&nbsp;&nbsp;&nbsp; 259200&nbsp;&nbsp;&nbsp; # Seconds deferred before third DSN is sent
Host_in_title: 0&nbsp;&nbsp;&nbsp; # If NZ, show hostname in system tray and taskbar
[MercuryC]
# Session_logging:&nbsp; G:\&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Directory to write session transcripts
host:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # mail mail host which relays for us
scratch:&nbsp;&nbsp;&nbsp;&nbsp; C:\xampp\MERCURYMAIL\Mercury&nbsp;&nbsp; # Where we can write temp files
poll:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 30&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Seconds between queue polling cycles
returnlines: 15&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # How many lines of failed messages to return
failfile:&nbsp;&nbsp;&nbsp; C:\xampp\MERCURYMAIL\Mercury\FAILURE.MER&nbsp; # Delivery failure template
esmtp:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Yes, we want to use ESMTP extensions
[MercuryE]
Poll : 15
Timeout : 60
Log_Verbose : 0
DNS_Timeout : 20
DNS_Retries : 4
Transcripts : 1
MaxThreads : 10
[MercuryD]
scratch&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; C:\xampp\MERCURYMAIL\Mercury
# Timeout : 30
# Poll : 120&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # How often to check hosts for new mail (seconds)
[MercuryS]
Debug : 1
Timeout : 30
Relay : 0
Strict_Relay : 1
Allow_Illegals : 0
SSL_Mode : 0
No_VRFY : 0
SMTP_ConnFlags : 0
[MercuryP]
Stack : 32768
Mark_Read : 1
SSL_Mode : 0
Login_Disabled : 0
UIDL_nul_list : 1
Timeout : 60
[MercuryX]
# Cmd_Delay: 10
# Cmd_Wait: 1
# IE4_Dialling: 0
# Use_ETRN: 1
# Clients_only: 1
# [Groups]
# testgroup&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; TESTGRP
[Domains]
mail: bobbylaptop
mail: 67.186.21.74
mail: 192.168.2.2
[Maiser]
Maiser:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Maiser&nbsp;&nbsp; # 'Username' of mail server account
Helpfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\xampp\MERCURYMAIL\Mercury\MAISER.HLP&nbsp;&nbsp; # Help sent on failed maiser requests
Lookupfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\xampp\MERCURYMAIL\Mercury\MAISER.LKP&nbsp;&nbsp; # Format file for the 'lookup' command
Send_dir:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\xampp\MERCURYMAIL\Mercury\SENDABLE&nbsp;&nbsp; # Directory for the 'send' command
Logfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\xampp\MERCURYMAIL\Logs\MAISER.LOG&nbsp;&nbsp; # Mail server log file
Notify:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\xampp\MERCURYMAIL\Mercury\TMP&nbsp;&nbsp; # Dir. for pending 'notify' commands
NoList:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; N&nbsp;&nbsp; # If 'Y', disable the 'list' command
Local_only:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Y&nbsp;&nbsp; # If 'Y', local 'notify' commands only
[MercuryH]
Logfile&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; C:\xampp\MERCURYMAIL\Logs\MERCURYH.LOG
Timeout : 30
[MercuryI]
Timeout : 120
Server_Port : 143
Idle_Timeout : 1800
SSL_Mode : 0
Login_Disabled : 0
[MercuryB]
Timeout : 120
Server_Port : 2224
Idle_Timeout : 1800
[Groups]
[Rewrite]
[Statistics]
StatFlags:&nbsp;&nbsp;&nbsp; 0&nbsp; # Statistical reporting settings
STF_Hours:&nbsp;&nbsp;&nbsp; 24&nbsp; # How often to write stat log files
STM_Hours:&nbsp;&nbsp;&nbsp; 24&nbsp; # How often to e-mail stat log files</p><p>
</p><p>Thanks again for spending the time to try to help me on this, i'm sorry that i'm not real intune to the mail server, this is only my first time trying to do this. If there is any other information that you need that i haven't provided that will help out please let me know and i'll try to provide it. Thanks again guys
