Odd problems after upgrading from 3.x to 4.x.
Is there a way to force Pegasus to "see" these?
Should be automatic if they are in the program or home mail directories.  Use Help | About Pegasus Mail | Info to get the current directory names.
<blockquote>Is there a way to force Pegasus to "see" these?</blockquote>Should be automatic if they are in the program or home mail directories.  Use Help | About Pegasus Mail | Info to get the current directory names.
I'm still having odd problems after upgrading from 3.x to 4.x.
The first problem had to do with the NEW mail folder not showing. I fixed this by rename HIERARCH.PM as recommended by forum members.
Now I can't see my adrdess books or distribution lists in Pegasus. I can see the ADD*.* and *.PML files in my Peg mail folder.
Regards,
Charles
<p>I'm still having odd problems after upgrading from 3.x to 4.x. </p><p>The first problem had to do with the NEW mail folder not showing. I fixed this by rename HIERARCH.PM as recommended by forum members.</p><p>Now I can't see my adrdess books or distribution lists in Pegasus. I can see the ADD*.* and *.PML files in my Peg mail folder. </p><p>Is there a way to force Pegasus to "see" these?</p><p>Regards,</p><p>Charles </p><p> </p>
