M/32 v4.72 - Will not run - Urgent Help..!
Peter,
As instructed, I changed the "Mercury.ini" entry to "# MercuryX" so that the module doesn't load when I start M/32, but how does that help..? I need the scheduler to be working.
So, I enabled the MercuryX module and restart M/32... Guess what..? Nothing works again.
M/32 is not loading in "Off-line mode". It is already in "On-line mode", so I selected "Off-line" and On-line", but it makes no difference.
I'm going back to v4.62... Sorry.
Regards. SJS.
<p>Peter,</p><p>As instructed, I changed the "Mercury.ini" entry to "# MercuryX" so that the module doesn't load when I start M/32, but how does that help..? I need the scheduler to be working.</p><p>So, I enabled the MercuryX module and restart M/32... Guess what..? Nothing works again.</p><p>M/32 is not loading in "Off-line mode". It is already in "On-line mode", so I selected "Off-line" and On-line", but it makes no difference.</p><p>I'm going back to v4.62... Sorry.</p><p> </p><p>Regards. SJS. </p>
I have upgraded from v4.62 to v4.72, but when M/32 is restarted it will not run. I simply upgrade and did not install the native service option.
I have modules C, D and X loaded. The Task Scheduler X simply says "Waiting for processes to", but does nothing.
HELP..!
Regards. SJS.
<p>I have upgraded from v4.62 to v4.72, but when M/32 is restarted it will not run. I simply upgrade and did not install the native service option. </p><p>I have modules C, D and X loaded. The Task Scheduler X simply says "Waiting for processes to", but does nothing.</p><p>HELP..!</p><p> </p><p>Regards. SJS.  </p>
Put a comment in front of MercuryX in Mercury.ini, like this:
[Protocols]
MERCURYS.DLL
MERCURYP.DLL
MERCURYE.DLL
# MERCURYC.DLL
# MERCURYD.DLL
# MERCURYH.DLL
# MERCURYF.DLL
# MERCURYW.DLL
# MERCURYX.DLL
MERCURYI.DLL
# MERCURYB.DLL
<P>Put a comment in front of MercuryX in Mercury.ini, like this:</P><PRE>[Protocols] MERCURYS.DLL MERCURYP.DLL MERCURYE.DLL # MERCURYC.DLL # MERCURYD.DLL # MERCURYH.DLL # MERCURYF.DLL # MERCURYW.DLL # MERCURYX.DLL MERCURYI.DLL # MERCURYB.DLL </PRE>
I assume that there is a bug with the v4.72 installer and I have to remove M/32 X module.
I also assume that I have to add it back and re-enter the schedule times, or does M/32 X no longer work properly..?
Thanks. SJS
<p>I assume that there is a bug with the v4.72 installer and I have to remove M/32 X module.</p><p>I also assume that I have to add it back and re-enter the schedule times, or does M/32 X no longer work properly..? </p><p> </p><p>Thanks. SJS  </p>
No there is nothing wrong with the installer - but there are reports here that suggest that MercuryX in 4.72 loads the entire Mercury in Off-Line mode, and you have to uncheck the off-line, http://community.pmail.com/forums/thread/18404.aspx - but I haven't checked this myself.
<P>No there is nothing wrong with the installer - but there are reports here that suggest that MercuryX in 4.72 loads the entire Mercury in Off-Line mode, and you have to uncheck the off-line, <A href="http://community.pmail.com/forums/thread/18404.aspx">http://community.pmail.com/forums/thread/18404.aspx</A> - but I haven't checked this myself.</P>
