Another odd problem in v4.x
That's always the way Pegasus has worked. It's a remnant of times when disk space was limited and expensive!
In order to save a copy of attachments, the easiest thing to do is to put yourself on the BCC list.
Hope this helps.
<p>That's always the way Pegasus has worked. It's a remnant of times when disk space was limited and expensive! </p><p>In order to save a copy of attachments, the easiest thing to do is to put yourself on the BCC list.</p><p>Hope this helps. </p>
When I send an eMail with an attachment using v4.x, the recipient gets  the attachment. However, I can't see the attachment in the version of the eMail in the SENT MAIL folder. The text ref to the attachment is there, but NOT the attachment itself.
Is this behaviour normal?
I can't remember if this is how v3.x behaved.
 Regards,
Charles
<p>When I send an eMail with an attachment using v4.x, the recipient gets  the attachment. However, I can't see the attachment in the version of the eMail in the SENT MAIL folder. The text ref to the attachment is there, but NOT the attachment itself. </p><p>Is this behaviour normal? </p><p>I can't remember if this is how v3.x behaved. </p><p> Regards,</p><p>Charles </p>
