[quote user="MilliBit"]
Some reporting/logging options do not work for me:
- notify  of new mail using a floating "telltale" window
 -  animate the icon (flap its wings) when new mail arrives
 -  play a newmail alert sound (only when I push the test button the sound rings).
They do not work, neither under Win98SE nor under WinXPSP3, neither in Pegasus Mail 4.51 nor in its previous version. Checking and unchecking, with or without restart of Pegasus Mail, does not help.
Does anybody  have a suggestion for me how to solve this?
Perhaps something is wrong in pmail.ini; can anybody tell me how the default settings for these options look in pmail.ini?
Remember those only work when mail will actually stay in the new mail folder. So if you have a filterrule that moves your incoming mail out of the new mail folder (like I have), none of the above will work.
        [quote user="MilliBit"]<p>Some reporting/logging options do not work for me:</p><ul><li>notify&nbsp; of new mail using a floating "telltale" window</li><li> animate the icon (flap its wings) when new mail arrives</li><li> play a newmail alert sound (only when I push the test button the sound rings).
</li></ul><p>They do not work, neither under Win98SE nor under WinXPSP3, neither in Pegasus Mail 4.51 nor in its previous version. Checking and unchecking, with or without restart of Pegasus Mail, does not help.
</p><p>Does anybody&nbsp; have a suggestion for me how to solve this?
</p><p>[/quote]</p><p>&nbsp;</p><p>Remember those only work when mail will actually stay in the new mail folder. So if you have a filterrule that moves your incoming mail out of the new mail folder (like I have), none of the above will work.</p><p>&nbsp;</p>
Han van den Bogaerde - support@vandenbogaerde.net
Member of Pegasus Mail Support Group.
My own Pegasus Mail related web information:
http://www.vandenbogaerde.net/pegasusmail/
