Pegasus Mail Suggestions
Search within PMail's Help
Unlike most windows programs, PMail's Help only has "Contents" and "Index." Missing is the "Search." If you are like me, you usually want to search for a command, structure, or value to be defined or used. I hope that this will be added back in the next release.
<p>Unlike most windows programs, PMail's Help only has "Contents" and "Index." Missing is the "Search." If you are like me, you usually want to search for a command, structure, or value to be defined or used. I hope that this will be added back in the next release.</p><p> </p>
