Unlike most windows programs, PMail's Help only has "Contents" and "Index." Missing is the "Search." If you are like me, you usually want to search for a command, structure, or value to be defined or used. I hope that this will be added back in the next release.
<p>Unlike most windows programs, PMail's Help only has "Contents" and "Index." Missing is the "Search." If you are like me, you usually want to search for a command, structure, or value to be defined or used. I hope that this will be added back in the next release.</p><p>&nbsp;</p>
