I have a problem with variable signatures . After modifiying the rquotes.r file, trying to compile it by rescom, I am getting an error message
Error rquotes.r 27: expected identifier name <1>
1 compilation error
The files rquotes.rsh and rquotes.h are issued, but they are not running, although I entered ~! in the signature file. The siganture shows only the text I wrote into the signature file, and leaves the variable signature as not existing.
I am running Pegasus 4.41 german version - on Win 2000 Pro - Pegasus is located on the server, while the workstations getting access by using -i xxxx
Thanks for your help
UIwe
<p>Hi,
</p><p>I have a problem with variable signatures . After modifiying the rquotes.r file, trying to compile it by rescom, I am getting an error message</p><p>Error rquotes.r 27: expected identifier name &lt;1&gt;</p><p>1 compilation error</p><p>The files&nbsp; rquotes.rsh and rquotes.h are issued, but they are not running, although I entered ~! in the signature file. The siganture shows only the text I wrote into the signature file, and leaves the variable signature as not existing.</p><p>I am running Pegasus 4.41 german version - on Win 2000 Pro - Pegasus is located on the server, while the workstations getting access by using -i xxxx</p><p>&nbsp;Thanks for your help</p><p>UIwe
&nbsp;</p><p>&nbsp;</p>
