Default identity problem
Hi Han,
Thank you very much. The problem was the SMTP!
Solved!
<p>Hi Han, </p><p>Thank you very much. The problem was the SMTP! </p><p>Solved!</p><p> </p>
I need your help with the following problem:
I have repeatedly been trying to change the email address in the Default identity of Pegasus by reconfiguring it in Toools / Internet Options. The new address is apparently recorded, but at the moment of trying to send emails from that identity the system chooses another address.
I tried to edit the pmail.ini file and only found the other identities, not the Default identity. In the first part of pmai.ini I found two apparently relevant lines:
* Internet E-mail Address
and
* Default reply-to address
In both cases the lines show the right address, yet the system does not send emails from the Default identity with that address.
I installed the 4.51 versión and the problem continues.
What do you suggest?
Thank you very much,
Gonzalo J. Auza
<p>Hello, I need your help with the following problem: I have repeatedly been trying to change the email address in the Default identity of Pegasus by reconfiguring it in Toools / Internet Options. The new address is apparently recorded, but at the moment of trying to send emails from that identity the system chooses another address. I tried to edit the pmail.ini file and only found the other identities, not the Default identity. In the first part of pmai.ini I found two apparently relevant lines: * Internet E-mail Address and * Default reply-to address      In both cases the lines show the right address, yet the system does not send emails from the Default identity with that address. I installed the 4.51 versión and the problem continues. What do you suggest? Thank you very much,</p><p>Gonzalo J. Auza </p>
[quote user="ontzalu"]
and
Gonzalo J. Auza
Go Tools -> options -> Outgoing Mail -> Sending mail. Is the default reply address set?
It can be that your ISP forces your mail to be from a specific address.
You can run a debug session (tools -> internet options -> create a session logging) to see exactly what's sent to your ISP's server.
[quote user="ontzalu"]<p>Hello, I need your help with the following problem: I have repeatedly been trying to change the email address in the Default identity of Pegasus by reconfiguring it in Toools / Internet Options. The new address is apparently recorded, but at the moment of trying to send emails from that identity the system chooses another address. I tried to edit the pmail.ini file and only found the other identities, not the Default identity. In the first part of pmai.ini I found two apparently relevant lines: * Internet E-mail Address and * Default reply-to address      In both cases the lines show the right address, yet the system does not send emails from the Default identity with that address. I installed the 4.51 versión and the problem continues. What do you suggest? Thank you very much,</p><p>Gonzalo J. Auza </p><p>[/quote]</p><p> </p><p>Go Tools -> options -> Outgoing Mail -> Sending mail. Is the default reply address set? </p><p>It can be that your ISP forces your mail to be from a specific address. </p><p>You can run a debug session (tools -> internet options -> create a session logging) to see exactly what's sent to your ISP's server.</p><p> </p>
