I wasn't able to find an answer to my problem on this forum, although it should not be uncommon. I cannot send mail with MercuryE. The DNS are manually and correctly set.  A log extract:
E 20091012 204828 4ad372a8 Processing of job MO0008B0 incomplete or failed.
T 20091012 204828 4ad372a3 Job MO0008B5 processing complete.
T 20091012 204828 4ad372a5 Job MO0008B3 processing complete.
T 20091012 204828 4ad372a6 Job MO0008B2 processing complete.
T 20091012 204828 4ad372a7 Job MO0008B1 processing complete.
E 20091012 204828 4ad372a1 Processing of job MO0008B7 incomplete or failed.
T 20091012 204828 4ad372aa Job MO0008AE processing complete.
T 20091012 204828 4ad372a9 Job MO0008AF processing complete.
T 20091012 204828 4ad372a4 Job MO0008B4 processing complete.
T 20091012 204828 4ad372a8 Job MO0008B0 processing complete.
T 20091012 204828 4ad372a1 Job MO0008B7 processing complete.
T 20091012 205015 4ad372ab Begin processing job MO000013 from postmaster@[<my correctly set fix ip>]
T 20091012 205031 4ad372ac Begin processing job MO000011 from postmaster@[<my correctly set fix ip>]
T 20091012 205031 4ad372ad Begin processing job MO000012 from postmaster@[<my correctly set fix ip>]
T 20091012 205031 4ad372ae Begin processing job MO000015 from postmaster@[<my correctly set fix ip>]
T 20091012 205031 4ad372af Begin processing job MO000017 from postmaster@[<my correctly set fix ip>]
T 20091012 205031 4ad372b0 Begin processing job MO000018 from postmaster@[<my correctly set fix ip>]
W 20091012 205036 4ad372ab Error connecting to primary server '209.85.223.91'.
W 20091012 205052 4ad372ae Error connecting to primary server '209.85.223.91'.
W 20091012 205052 4ad372ad Error connecting to primary server '209.85.223.91'.
W 20091012 205052 4ad372af Error connecting to primary server '209.85.223.91'.
W 20091012 205052 4ad372b0 Error connecting to primary server '209.85.223.91'.
W 20091012 205052 4ad372ac Error connecting to primary server '209.85.223.91'.
W 20091012 205058 4ad372ab Error connecting to alternate server '209.85.210.52'.
My internet connection is via a cable modem, but my ISP always designates the same IP address. The same IP address is set in the 'Identify myself as' field too.
I attempt to send a simple email message to my own accounts on gmail, gmx etc. - no success... What can be the problem?
I managed to connect via telnet to some server on port 25, so I guess my ISP is not blocking it, but not to the servers which are resolved as gmail, gmx...?
Thanks for your help
<p>Hello,</p><p>I wasn't able to find an answer to my problem on this forum, although it should not be uncommon. I cannot send mail with MercuryE. The DNS are manually and correctly set.&nbsp; A log extract:</p><p>E 20091012 204828 4ad372a8 Processing of job MO0008B0 incomplete or failed.
T 20091012 205015 4ad372ab Begin processing job MO000013 from postmaster@[&lt;my correctly set fix ip&gt;]
T 20091012 205031 4ad372ac Begin processing job MO000011 from postmaster@[&lt;my correctly set fix ip&gt;]
T 20091012 205031 4ad372ad Begin processing job MO000012 from postmaster@[&lt;my correctly set fix ip&gt;]
T 20091012 205031 4ad372ae Begin processing job MO000015 from postmaster@[&lt;my correctly set fix ip&gt;]
T 20091012 205031 4ad372af Begin processing job MO000017 from postmaster@[&lt;my correctly set fix ip&gt;]
T 20091012 205031 4ad372b0 Begin processing job MO000018 from postmaster@[&lt;my correctly set fix ip&gt;]
W 20091012 205058 4ad372ab Error connecting to alternate server '209.85.210.52'. </p><p>My internet connection is via a cable modem, but my ISP always designates the same IP address. The same IP address is set in the 'Identify myself as' field too.</p><p>I attempt to send a simple email message to my own accounts on gmail, gmx etc. - no success... What can be the problem? </p><p>I managed to connect via telnet to some server on port 25, so I guess my ISP is not blocking it, but not to the servers which are resolved as gmail, gmx...?</p><p>Thanks for your help
