[quote user="Eshtaol"]
This may be an easy one for you folks but baffling to me,
I have friends who are sending power point presentations as an attachment with .pps
I used to be able to view but recently cannot. I can can open all other attachments except
the powerpoint. Could I have accidently changed a setting somewhere? What do I need to do?
Thanks for help in advance
You need a an application which can read PowerPoint files: PowerPoint itself (part of MSOffice), PowerPoint Viewer from Microsoft which can read but not create PowerPoint files, or OpenOffice.org's Presentation.  If the file association is corrupted, how to fix it varies with OS, but installing (or reinstalling) PP Viewer (free from MS) should cure the problem.
[quote user="Eshtaol"]<p>This may be an easy one for you folks but baffling to me,
</p><p>I have friends who are sending power point presentations as an attachment with .pps
</p><p>I used to be able to view but recently cannot. I can can open all other attachments except</p><p>the powerpoint. Could I have accidently changed a setting somewhere? What do I need to do?</p><p>&nbsp;</p><p>Thanks for help in advance
</p><p>[/quote]</p><p>&nbsp;</p><p>You need a an application which can read PowerPoint files: PowerPoint itself (part of MSOffice), PowerPoint Viewer from Microsoft which can read but not create PowerPoint files, or OpenOffice.org's Presentation.&nbsp; If the file association is corrupted, how to fix it varies with OS, but installing (or reinstalling) PP Viewer (free from MS) should cure the problem.</p><p>&nbsp;</p><p>&nbsp;</p>
