Seems earlier this week Fastmail has changed the SSL version causing Pegasus to fail if SSL (or TLS) to connect, dropping down to nonsecure (IMAP port 143) it works.
Reading the blog:
SSL security updated
November 18, 2009 — Rob Mueller
Due to a recently discovered SSL man-in-the-middle flaw, I’ve upgraded our web, IMAP and POP proxy servers to disable SSL renegotiation.
At the same time, I’ve disabled SSLv2 protocol (it’s been deprecated 1996) and disabled all “LOW” and “EXPORT” ciphers.
In theory, there should be no user visible changes, but some very, very old email clients or browsers may experience problems. Unfortunately in those cases, people are either going to have to use non-SSL access, or upgrade their email client/browser to a newer version.
Reading the blog and forums for Fastmail I was able to find this tidbit:
Try changing the hostname to insecuressl.messagingengine.com. We've added a couple of extra IP addresses and configured that hostname with SSLv2 support.
Hopefully the SSL issue can be addressed by David.
Using Mulberry I was able to connect to the site via the mail.messagingengine.com address via IMAP port 993. Firewall was not changed (allows Pegasus on the SSL and non SSL ports to the mail server).
If anyone else has an idea how to configure Pegasus that would be great.
Thank you
<P>Seems earlier this week Fastmail has changed the SSL version causing Pegasus to fail if SSL (or TLS) to connect, dropping down to nonsecure (IMAP port 143) it works.</P><P>Reading the blog:</P><P>-------------</P><P>SSL security updated
</P><P>---------------</P><P>Reading the blog and forums for Fastmail I was able to find this tidbit:</P><P>Try changing the hostname to <STRONG>insecuressl.messagingengine.com</STRONG>. We've added a couple of extra IP addresses and configured that hostname with SSLv2 support.</P><P>-----------------</P><P>Hopefully the SSL issue can be addressed by David.</P><P>Using Mulberry I was able to connect to the site via the <STRONG>mail.messagingengine.com </STRONG>address via IMAP port 993. Firewall was not changed (allows Pegasus on the SSL and non SSL ports to the mail server).</P><P>
</P><P>If anyone else has an idea how to configure Pegasus that would be great.</P><P>Thank you</P><P>
</P>
