I went thru this about a month or so ago and thought the problem was fixed. I guess not... I am running WindowsXP SP3 and really never had this problem before I installed Pegasus v.4.51 about a month or so ago. Earlier installations never did this.
I have re-sized and re-sized my  windows over and over again but this annoying problem has remained unfixed.
When  I open Pmail, it opens fully opened, edge to edge with no scroll bars visible. I dragged all sides manually so the maximized box at top right is visible.
When I open any window save for "Start a New Mail Message" they all open in a smaller size with the upper-right corner and the 3 choices boxes (minimize, maximize, close) visible. No scroll bars visible in them, either. I hit 'maximize' and the windows open fully. After I shut down and then re-open Pmail later, any window I open (again, save the "start new...") opens in its non-maximized size (like before) until I hit 'maximize'. This seems to all be working fine.
 If I want to send an email and hit the "start new..." window, it opens in a (sorta) maximized size with the right side under a newly-appeared scroll bar which covers the 3 upper-right corner boxes and entire right edge. I drag the window down, manually re-size it to a size about the same as all the other windows open to until I change it.
If I close the write window and re-open it (or close Pmail entirely and re-open) the write window is at the smaller, re-sized size. If I maximize it and write a new email, send it and close, the write window will re-open with the upper-right corner obscured again! None of the other windows does this. They all open in the smaller size I manually set them to. Do I have to re-size the write window manually (center box at top right) to the smaller size every time I send a message? This doesn't seem right nor did  this happen with earlier versions of Pmail.
 Does this make sense? All windows, no scroll bars anywhere, open in the size I set them to except the "write new mail" window. It never holds the re-sized size like the others.
Thanks to anyone who can help with this. We tried and tried a bunch last time and I thought it was fixed but I guess something further needs to be done.
 Robert
<p>I went thru this about a month or so ago and thought the problem was fixed. I guess not... I am running WindowsXP SP3 and really never had this problem before I installed Pegasus v.4.51 about a month or so ago. Earlier installations never did this.
</p><p>I have re-sized and re-sized my&nbsp; windows over and over again but this annoying problem has remained unfixed. </p><p>When&nbsp; I open Pmail, it opens fully opened, edge to edge with no scroll bars visible. I dragged all sides manually so the maximized box at top right is visible.</p><p>When I open any window save for "Start a New Mail Message" <i>they</i> all open in a smaller size with the upper-right corner and the 3 choices boxes (minimize, maximize, close) visible. No scroll bars visible in them, either. I hit 'maximize' and the windows open fully. After I shut down and then re-open Pmail later, any window I open (again, save the "start new...") opens in its non-maximized size (like before) until I hit 'maximize'. This seems to all be working fine.</p><p>&nbsp;If I want to send an email and hit the "start new..." window, it opens in a (sorta) maximized size with the right side under a <u><i>newly-appeared scroll bar</i></u> which covers the 3 upper-right corner boxes and entire right edge. I drag the window down, manually re-size it to a size about the same as all the other windows open to until I change it.</p><p>If I close the write window and re-open it (or close Pmail entirely and re-open) the write window is at the smaller, re-sized size. If I maximize it and write a new email, send it and close, the write window will re-open with the upper-right corner obscured again!<i> </i><u><i>None</i></u> of the other windows does this. They all open in the smaller size I manually set them to. Do I have to re-size the write window manually (center box at top right) to the smaller size every time I send a message? This doesn't seem right nor did&nbsp; this happen with earlier versions of Pmail.
</p><p>&nbsp;Does this make sense? All windows, no scroll bars anywhere, open in the size I set them to except the "write new mail" window. It <i>never </i>holds the re-sized size like the others.</p><p>Thanks to anyone who can help with this. We tried and tried a bunch last time and I thought it was fixed but I guess something further needs to be done. </p><p>&nbsp;Robert
</p><p>&nbsp;</p>
