Pegasus Mail Suggestions
Shortcut for removing attachments...
Ok,
At first I was searching for a shortcut to remove attachments from the mail. I tried Delete key, but it did not work. So I found that Alt+R is removing attachment that we want in attachments tab. So my problem has been solved :)
<p>Ok,</p><p> </p><p>At first I was searching for a shortcut to remove attachments from the mail. I tried Delete key, but it did not work. So I found that Alt+R is removing attachment that we want in attachments tab. So my problem has been solved :)</p>
Please add delete key to remove attachments in compose window...
Thank you...
<p>Hello,</p><p> </p><p>Please add delete key to remove attachments in compose window...</p><p> </p><p>Thank you... </p>
[quote user="wakeup"]
Thank you...
I wonder what you mean, as there already is such a key under the Attachments tab, named "Remove attachment".
Steffan
[quote user="wakeup"]<p>Hello,</p><p> </p><p>Please add delete key to remove attachments in compose window...</p><p> </p><p>Thank you... </p><p>[/quote]</p><p>I wonder what you mean, as there already is such a key under the Attachments tab, named "Remove attachment".</p><p>Cheers! Steffan </p>
No i mean a shortcut...
<p>Hello,</p><p> </p><p>No i mean a shortcut... </p>
A keyboard shortcut? I'm sure the delete key will work in the current version - if you have the attachment selected. Does that count?
Also, i noticed now that if we press Alt+R it removes the attachment we selected...
