Using Pmail 4.51 with MS Word 2003
I think you are refering to my SendDoc macro, available at:
http://community.pmail.com/files/folders/codesnippets/entry1771.aspx
<p>I think you are refering to my SendDoc macro, available at:</p><p><a href="http://community.pmail.com/files/folders/codesnippets/entry1771.aspx">http://community.pmail.com/files/folders/codesnippets/entry1771.aspx</a> </p><p>Martin </p>
Hi Folks,
I tried doing a search and yielded some out of date post so, let me ask fresh?! Is there anyway I can get Ms Word 2003 to work with Pmail 4.51 so that when I use the SEND TO option listed under the FILE menu list that it will send the document to Pmail? I read something about a macro but could find any links to where it could be found or if it would even solve the matter.
Thanks Much!!
Clint
<p>Hi Folks,</p><p>I tried doing a search and yielded some out of date post so, let me ask fresh?! Is there anyway I can get Ms Word 2003 to work with Pmail 4.51 so that when I use the SEND TO option listed under the FILE menu list that it will send the document to Pmail? I read something about a macro but could find any links to where it could be found or if it would even solve the matter.</p><p> </p><p>Thanks Much!!</p><p>Clint </p>
Try MAPI.
Try <a href="/files/folders/pegadd/entry25482.aspx" target="_blank" mce_href="/files/folders/pegadd/entry25482.aspx">MAPI</a>.
