Hi
Not sure if this will be of interest to any one [:S]
Using Alkit VNC (http://w2.alkit.se/avnc/) it's possible to share just the Mercury32 Window via VNC.
This allows you to view and interact with the GUI via a VNC Viewer (I've tried Linux & Win) or a Web Browser.
Seems to work well, with a couple of little issues.
1: Mercury32 must be running full screen on the remote PC
2: The Mercury top tool bar is missing from the remote viewer.
(but you can still click at the top and get the drop down menus. !!)
3: Via the Web Browser the mouse seems slightly out.. You have to click a little lower that you would normally.
Not to sure if anyone will try this but though I'd post it anyway !!
Anyone have a better solution that will work on Win & Linux, please post details.
Regards
<p>Hi</p><p>Not sure if this will be of interest to any one&nbsp; [:S]</p><p>Using Alkit VNC (http://w2.alkit.se/avnc/) it's possible to share just the Mercury32 Window via VNC.</p><p>This allows you to view and interact with the GUI via a VNC Viewer (I've tried Linux &amp; Win) or a Web Browser.</p><p>Seems to work well, with a couple of little issues.
1: Mercury32 must be running full screen on the remote PC</p><p>2: The Mercury top tool bar is missing from the remote viewer.
(but you can still click at the top and get the drop down menus. !!) </p><p>3: Via the Web Browser the mouse seems slightly out..&nbsp; You have to click a little lower that you would normally.</p><p>Not to sure if anyone will try this but though I'd post it anyway !!</p><p>Anyone have a better solution that will work on Win &amp; Linux, please post details.</p><p>Regards
</p><p>&nbsp;</p>
