[quote user="David Briggs"]
I have been using v4.51 for a few weeks since installing on a new PC running Windows 7. I had the now-you-don't-see-them toolbar buttons, so I followed the instructions to download the update package rather than the full installer. However, it did not recognise my installed version and would not upgrade it.
I was able to install the full kit in upgrade mode, and everything is working OK, so the problem is sidestepped.
Hope that helps anyone else who runs into the same issue.
David
What directory did you install Pegasus Mail in? See the following thread for some hints ...
[quote user="David Briggs"]<p>I have been using v4.51 for a few weeks since installing on a new PC running Windows 7. I had the now-you-don't-see-them toolbar buttons, so I followed the instructions to download the update package rather than the full installer. However, it did not recognise my installed version and would not upgrade it. </p>
<p>I was able to install the full kit in upgrade mode, and everything is working OK, so the problem is sidestepped.</p>
<p>Hope that helps anyone else who runs into the same issue.</p>
<p>David</p><p>[/quote]</p><p>&nbsp;What directory did you install Pegasus Mail in? See the <a href="http://community.pmail.com/forums/thread/21561.aspx" target="_blank">following thread</a> for some hints ...</p>
