Mercury V4.6,
MercuryS: strict local relaying enabled; Connection control: all local LAN all addresses allowed
Normal routing to ISP is via the DSL router on the local LAN. This works faultlessly
The DSL link went down recently, so I used a mobile phone connection to the ISP. Receiving mail via POP3 was no problem, but all outgoing messages were rejected as follows:
The local mail transport system has reported the following problems
it encountered while trying to deliver your message:
*** yyy@zzz.com
554 5.7.1 <yy@zzz.com>: Relay access denied
This occurred despite the following Mercury configuration changes:
MercuryS: all relaying restrictions unticked; Connection control: address range including the mobile phone IP address 'ALLOWED' added
MercuryP: Connection control: address range including the mobile phone IP address 'ALLOWED' added
Despite this, Mercury would only download POP3 incoming mail. All SMTP mail was rejected 'Relay access denied'
Any ideas what the problem is?
<p>Mercury V4.6,</p><p>MercuryS:&nbsp; strict local relaying enabled; Connection control: all local LAN all addresses allowed</p><p>Normal routing to ISP is via the DSL router on the local LAN.&nbsp; This works faultlessly</p><p>&nbsp;</p><p>
The DSL link went down recently, so I used a mobile phone connection to the ISP.&nbsp; Receiving mail via POP3 was no problem, but all outgoing messages were rejected as follows:</p><p>The local mail transport system has reported the following problems
*** yyy@zzz.com
554 5.7.1 &lt;yy@zzz.com&gt;: Relay access denied
</p><p>-------------------------------------------------------------------
</p><p>&nbsp;</p><p>This occurred despite the following Mercury configuration changes:</p><p>MercuryS:&nbsp; all relaying restrictions unticked; Connection control: address range including the mobile phone IP address 'ALLOWED'&nbsp; added</p><p>MercuryP:&nbsp; Connection control: address range including the mobile phone IP address 'ALLOWED'&nbsp; added</p><p>Despite this, Mercury would only download POP3 incoming mail.&nbsp; All SMTP mail was rejected 'Relay access denied'</p><p>&nbsp;</p><p>Any ideas what the problem is?</p><p>&nbsp;</p><p>&nbsp;</p><p>&nbsp;</p>
