Problem with outgoing mail
Thank you very much for your assistance.  Your suggested fix did solve the problem.  I very much appreciate your help and your quick response.
My email is set up through the AOL server and my address is howard@cpe-services.com
I just set up Pegasus and am receiving incoming mail without any problem. However I am unable to send outgoing mail.  Every attempt bounces back with the following message:
Delivery has failed on the enclosed message for the following reasons reported either by the mail delivery system on the mail relay host or the local TCP/IP transport module:
553 5.7.1 howard@cpe-services.com: Sender address rejected: not logged in
I have tried every setting imaginable, but can not send any mail...although receiving it is not aa problem.  CAN ANYONE HELP!!!!!
Thanks oyu for any assistance you can offer.
<P>My email is set up through the AOL server and my address is <A href="mailto:howard@cpe-services.com">howard@cpe-services.com</A></P> <P>I just set up Pegasus and am receiving incoming mail without any problem. However I am unable to send outgoing mail.  Every attempt bounces back with the following message:</P> <P>Delivery has failed on the enclosed message for the following reasons reported either by the mail delivery system on the mail relay host or the local TCP/IP transport module:</P> <P>553 5.7.1 <A href="mailto:howard@cpe-services.com">howard@cpe-services.com</A>: Sender address rejected: not logged in</P> <P>I have tried every setting imaginable, but can not send any mail...although receiving it is not aa problem.  CAN ANYONE HELP!!!!!</P> <P>Thanks oyu for any assistance you can offer.  </P>
> I have tried every setting imaginable, but can not send any mail...although receiving it is not a problem.  CAN ANYONE HELP!!!!!
You need to go to Tools | Internet options | (Sending) SMTP, edit the SMTP setup, select the "Security" tab and select the "SMTP Authentication".  I use the second option since I use AOL via IMAP4 without a POP3 account; you could use option 3 and select your AOL POP3 setup.
> 553 5.7.1 howard@cpe-services.com: Sender address rejected: not logged in > > I have tried every setting imaginable, but can not send any mail...although receiving it is not a problem.  CAN ANYONE HELP!!!!! You need to go to Tools | Internet options | (Sending) SMTP, edit the SMTP setup, select the "Security" tab and select the "SMTP Authentication".  I use the second option since I use AOL via IMAP4 without a POP3 account; you could use option 3 and select your AOL POP3 setup.
