Been using Pegasus since the early days of Win 95
Was using 4.41 since release for some time now -- never had any problems with it
Moved up to 4.51 and the problems started.
Using an AMD K6II 500Mhz and an nVidia graphics card --384 MB memory -- WIndows 98SE
Version 4.41 works great on this system. ( Never crashes)
With version 4.51 this is what happens
After a short while ( especially working with folders ) the icons ( glyphs ) on the toolbar fade out.
Then the icons in the folder windows start going transparent as well and the lines fade out -- font goes funny as well.
Everything slows down and it becomes impossible to work -- note the program does not "crash" as such
Often you see an error message -- "Unable to create font"
In order to carry on working you have to exit the program and then start it again.
Windows 98SE itself is stable and I hardly ever have to reboot it.
Pegasus only lasts about and hour ( depending on how active you are with it ) before it "fades-out" again
I am using the latest iconv.dll from this site -- but I think that this is where the problem may lie.
I know -- I know -- I should upgrade my machine and go to XP or something -- thing is the old girl still has some life in her.
This is driving me CRAZY.
I would like to use 4.51 as I find the new features it has very handy (autofilter on folders for one )
WHAT can I do ????
Is there an updated iconv.dll -- or perhaps some workaround ?
Chris in South Africa
<p>Been using Pegasus since the early days of Win 95</p><p>Was using 4.41 since release for some time now -- never had any problems with it
</p><p>Moved up to 4.51 and the problems started.</p><p>&nbsp;</p><p>Using an AMD K6II 500Mhz and an nVidia graphics card --384 MB memory -- WIndows 98SE
</p><p>Version 4.41 works great on this system. ( Never crashes)
</p><p>&nbsp;</p><p>With version 4.51 this is what happens</p><p>After a short while ( especially working with folders ) the icons ( glyphs ) on the toolbar fade out.</p><p>Then the icons in the folder windows start going transparent as well and the lines fade out -- font goes funny as well.
</p><p>Everything slows down and it becomes impossible to work -- note the program does not "crash"&nbsp; as such</p><p>Often you see an error message -- "Unable to create font"</p><p>In order to carry on working you have to exit the program and then start it again.</p><p>Windows 98SE itself is stable and I hardly ever have to reboot it.
</p><p>Pegasus only lasts about and hour ( depending on how active you are with it ) before it "fades-out" again
</p><p>I am using the latest iconv.dll from this site -- but I think that this is where the problem may lie.
</p><p>&nbsp;</p><p>I know -- I know -- I should upgrade my machine and go to XP or something -- thing is the old girl still has some life in her.
</p><p>&nbsp;</p><p>&nbsp;This is driving me CRAZY.</p><p>I would like to use 4.51 as I find the new features it has very handy (autofilter on folders for one )
</p><p>WHAT can I do ????</p><p>Is there an updated iconv.dll -- or perhaps some workaround ?</p><p>&nbsp;</p><p>Thanks</p><p>&nbsp;</p><p>Chris in South Africa
</p><p>&nbsp;</p><p>&nbsp;</p><p>&nbsp;</p>
