Running Mercuy with spamhalter ver 4.5.
Installed over existing version.
Can access SPAMHALTER from Mercuy32 config menu.
Have Mercury installed on a server and run from another PC. Mapped drive to Mercury as M:\.
When installing spamhalter, it installed itself in a spamhalter folder inside the Mercury directory. (so //Mercury/Spamhalter)
Appears spamhalter will not run this way if the spamhalter.dll is not in the root Mercury directory.
So, I copied the .dll and INI files to the root of Mercury. Basically, I have two versions of daemon.ini and spamhalter.ini and its all screwed up.
My spamhalter database exists in ..Mercury/spamhalter/spamhalter. Don't ask me how it got there.
My spamhalter does not work. I can edit all setting from Mercury Config-Spamhalter, however it does not add the X-spamhalter to all my incoming messages, so it is obviously not checking them.
However, if I send an email to the yesspam mailbox, the Mercury core says: *Job killed by Daemon Hummm...
So, my question is, during spamhalter install, is it supposed to install all the files in its own "Spamhalter" directory in the Mercury directory, or is it supposed to just put all its files DIRECTLY in the Mercury directory?
I could not even see spamhalter in the Merucry Configuration menu unless some of the config files were put in the root Mercury directory.
So, it got all messed up, and YEP I'm sure I'm partly to blame. Where is everything supposed to be?
Thanks!
MP
<P>Hello,</P>
<P>Running Mercuy with spamhalter ver 4.5.</P>
<P>Installed over existing version.</P>
<P>Can access SPAMHALTER from Mercuy32 config menu.</P>
<P>Have Mercury installed on a server and run from another PC.&nbsp; Mapped drive to Mercury as M:\.&nbsp; </P>
<P>When installing spamhalter, it installed itself in a spamhalter folder inside the Mercury directory. (so //Mercury/Spamhalter)</P>
<P>Appears spamhalter will not run this way if the spamhalter.dll is not in the root Mercury directory.</P>
<P>So, I copied the .dll and INI files to the root of Mercury.&nbsp; Basically, I have two versions of daemon.ini and spamhalter.ini and its all screwed up.</P>
<P>My spamhalter database exists in ..Mercury/spamhalter/spamhalter.&nbsp; Don't ask me how it got there.</P>
<P>My spamhalter does not work.&nbsp; I can edit all setting from Mercury Config-Spamhalter, however it does not add the X-spamhalter to all my incoming messages, so it is&nbsp;obviously not checking them.</P>
<P>However, if I send an email to the yesspam mailbox, the Mercury core says:&nbsp; &nbsp;*Job killed by Daemon&nbsp; Hummm...</P>
<P>So, my question is, during spamhalter install, is it supposed to install all the files in its own "Spamhalter" directory in the Mercury directory, or is it supposed to just put all its files DIRECTLY in the Mercury directory?</P>
<P>I could not even see spamhalter in the Merucry Configuration menu unless some of the config files were&nbsp;put in the root&nbsp;Mercury directory.</P>
<P>So, it got all messed up, and YEP I'm sure I'm partly to blame.&nbsp; Where is everything supposed to be?</P>
<P>Thanks!</P>
<P>MP</P>
<P mce_keep="true">&nbsp;</P>
