i do this because in spain are a several law in material of data protection, and i don't like have problems, but, thomas know this info, then, this is the real ini
Thomas, if i undrstand you well, i need put this line
HELPPC: helppc
HELPPC: helppc.org
HELPPC: [87.235.215.29] ; if you have a fixed IP address.
in Domains, it'strue?
# MERCURY.INI generated by Mercury Setup
# Sample Bindery Mode MERCURY.INI file (in fact, the one I use on
# my production server). This one implements most of the possible
# switches for each module, but you can edit it to do less if you
# wish. All the fields shown below are described in the file
# MGUIDE.HLP which is supplied in the Mercury archive.
# Anything after a '#' to the end of the line is a comment and
# is stripped out before parsing. Trailing and leading whitespace
# is also stripped before parsing. Many sample commands have been
# left in this file commented out for reference purposes.
[General]
myname: helppc.org # Canonical name for this server
timezone: +0001 # Time Zone to add to date fields
mailqueue: I:\MERCURY\QUEUE # Where mail should be put for delivery
smtpqueue: I:\MERCURY\QUEUE-OUT # Where the SMTP client should look for mail
newmail_path: I:\MERCURY\MAIL\~N # Where to find the users' WinPMail mailboxes.
secondary_queue: I:\MERCURY\queue
[Protocols]
MERCURYS.DLL
MERCURYP.DLL
MERCURYE.DLL
# MERCURYC.DLL
MERCURYD.DLL
# MERCURYH.DLL
# MERCURYF.DLL
# MERCURYW.DLL
# MERCURYX.DLL
MERCURYI.DLL
# MERCURYB.DLL
[Mercury]
failfile: i:\MERCURY\Mercury\FAILURE.MER # Delivery failure notification template
confirmfile: i:\MERCURY\Mercury\CONFIRM.MER # Delivery confirmation template
aliasfile: i:\MERCURY\Mercury\ALIAS.MER # System-wide alias file
synfile: i:\MERCURY\Mercury\SYNONYM.MER # User synonym database
listfile: i:\MERCURY\Mercury\LISTS.MER # List of lists
logfile: i:\MERCURY\Mercury\system.log # Traffic logging file
retpath: 1 # Do/Don't use 'return-path' for errors
bitnethost: cunyvm.cuny.edu # Relay host for '.bitnet' rewrites
poll: 10 # Seconds between queue polling cycles
scratch: i:\MERCURY\Scratch # Where we can write temp files
postmaster: admin # NetWare UIC of postmaster
broadcast: 0 # Yes, we want broadcast notifications, but
receipts: 1 # ... no broadcasts for receipt confirmations
PM_notify: 0 # Do/Don't send errors to the postmaster
change_owner: 0 # Change message ownership to recipient
RetryPeriod: 15 # Period between job retries (minutes)
MaxRetries: 20 # Maximum number of times a job can fail
TwoPasses: 0 # If NZ, process submission queue in 2 passes
Autoaddress: 0 # If NZ, auto-generate user addresses based on name
Daily_exit: 1 # If NZ, auto-restart each day after maintenance
Alt_Forward: 1 # If NZ, allow alternate forwarding specification
Maint_hour: 3 # Hour for daily maintenance (24-hour clock)
Retry_Mode: 1 # If NZ, use progressive backoff for queue retries
[MercuryC]
Failfile : i:\MERCURY\Mercury\FAILURE.MER
Poll : 30
Scratch : i:\MERCURY\Mercury
ReturnLines : 15
Timeout : 30
ESMTP : 1
POP3_Auth : 0
Log_Verbose : 0
[MercuryE]
HELO : correo.helppc.org
Session_logging : logs/smtpdir
Session_logmode : 0
Poll : 5
Timeout : 60
Nameservers : 192.168.100.205
Logfile : log.txt
Log_Verbose : 0
DNS_Timeout : 20
DNS_Retries : 4
Transcripts : 0
[MercuryD]
Timeout : 30
Poll : 60
[MercuryS]
Debug : 1
HELO : correo.helppc.com
Logfile : i:\MERCURY\Logs\MERCURYS.LOG
Timeout : 90
Relay : 0
Strict_Relay : 1
Server_Port : 125
Interface : 192.168.100.205
Allow_Illegals : 0
SMTP_Authentication : 3
Auth_File : i:\MERCURY\MAIL\SMTPMAIL.USR
Compliance_Settings : 424
Maximum_Failed_Rcpts : 5
Max_Relay_Attempts : 5
SSL_Mode : 0
ST_Blacklisting : 0
No_VRFY : 0
SMTP_ConnFlags : 0
[MercuryP]
Logfile : pop3_log.txt
Stack : 32768
Mark_Read : 1
SSL_Mode : 0
Login_Disabled : 0
Session_logging : logs/pop3
Session_logmode : 0
Timeout : 60
[MercuryX]
# Cmd_Delay: 10
# Cmd_Wait: 1
# IE4_Dialling: 0
# Use_ETRN: 1
# Clients_only: 1
# [Groups]
# testgroup : TESTGRP
[Domains]
helppc.org: helppc.org
**HELPPC: helppc
**HELPPC: helppc.org
**HELPPC: [87.235.215.29] ; if you have a fixed IP address.
[Maiser]
Helpfile: i:\MERCURY\Mercury\MAISER.HLP # Help sent on failed maiser requests
Lookupfile: i:\MERCURY\Mercury\MAISER.LKP # Format file for the 'lookup' command
Send_dir: i:\MERCURY\Mercury\SENDABLE # Directory for the 'send' command
Logfile: i:\MERCURY\Logs\MAISER.LOG # Mail server log file
Notify: i:\MERCURY\Mercury\TMP # Dir. for pending 'notify' commands
Local_only: N # If 'Y', local 'notify' commands only
Admin_Passwords: D:\MERCURY\MERCURY\maiser.pwd # File for mail server administrator passwords
[MercuryH]
Logfile : i:\MERCURY\Logs\MERCURYH.LOG
Timeout : 30
[MercuryI]
Scratch : i:\MERCURY\SCRATCH
Logfile : i:\MERCURY\Logs\imap.LOG
Timeout : 240
Server_Port : 143
Session_logging : i:\MERCURY\Logs
Session_logmode : 0
Idle_Timeout : 3600
SSL_Mode : 0
Login_Disabled : 0
[MercuryB]
Timeout : 120
Server_Port : 9080
Idle_Timeout : 1800
[Groups]
[Rewrite]
[Statistics]
StatFlags: 16 # Statistical reporting settings
StatFiles: i:\MERCURY\stats.mer # Directory to write stat log files
StatMail: # Address to send stat log files
STM_Hours: 2 # How often to e-mail stat log files
<P>i do this because in spain are a several law in material of data protection, and i don't like have problems, but, thomas know this info, then, this is the real ini</P>
<P>Thomas, if i undrstand you well, i need put this line </P>
<P>HELPPC:&nbsp; helppc
HELPPC:&nbsp; helppc.org
HELPPC:&nbsp; [87.235.215.29] ; if you have a fixed IP address.
in Domains, it'strue?</P>
<P mce_keep="true">&nbsp;</P>
<P>#&nbsp; MERCURY.INI generated by Mercury Setup
#&nbsp; Sample Bindery Mode MERCURY.INI file (in fact, the one I use on
#&nbsp; my production server). This one implements most of the possible
#&nbsp; switches for each module, but you can edit it to do less if you
#&nbsp; wish. All the fields shown below are described in the file
#&nbsp; MGUIDE.HLP which is supplied in the Mercury archive.
#&nbsp; Anything after a '#' to the end of the line is a comment and
#&nbsp; is stripped out before parsing. Trailing and leading whitespace
#&nbsp; is also stripped before parsing. Many sample commands have been
#&nbsp; left in this file commented out for reference purposes.
#</P>
<P>[General]
myname:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; helppc.org&nbsp;&nbsp;&nbsp; # Canonical name for this server
timezone:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; +0001&nbsp;&nbsp;&nbsp; # Time Zone to add to date fields
file_api:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # Use the file api instead of queues
mailqueue:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; I:\MERCURY\QUEUE&nbsp;&nbsp;&nbsp; # Where mail should be put for delivery
smtpqueue:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; I:\MERCURY\QUEUE-OUT&nbsp;&nbsp;&nbsp; # Where the SMTP client should look for mail
newmail_path:&nbsp;&nbsp;&nbsp; I:\MERCURY\MAIL\~N&nbsp;&nbsp;&nbsp; # Where to find the users' WinPMail mailboxes.
secondary_queue: I:\MERCURY\queue</P>
<P>[Protocols]
MERCURYS.DLL
MERCURYP.DLL
MERCURYE.DLL
# MERCURYC.DLL
MERCURYD.DLL
# MERCURYH.DLL
# MERCURYF.DLL
# MERCURYW.DLL
# MERCURYX.DLL
MERCURYI.DLL
# MERCURYB.DLL</P>
<P>[Mercury]
failfile:&nbsp;&nbsp;&nbsp;&nbsp; i:\MERCURY\Mercury\FAILURE.MER&nbsp;&nbsp;&nbsp; # Delivery failure notification template
confirmfile:&nbsp; i:\MERCURY\Mercury\CONFIRM.MER&nbsp;&nbsp;&nbsp; # Delivery confirmation template
aliasfile:&nbsp;&nbsp;&nbsp; i:\MERCURY\Mercury\ALIAS.MER&nbsp;&nbsp;&nbsp; # System-wide alias file
synfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; i:\MERCURY\Mercury\SYNONYM.MER&nbsp;&nbsp;&nbsp; # User synonym database
listfile:&nbsp;&nbsp;&nbsp;&nbsp; i:\MERCURY\Mercury\LISTS.MER&nbsp;&nbsp;&nbsp; # List of lists
logfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; i:\MERCURY\Mercury\system.log&nbsp;&nbsp;&nbsp; # Traffic logging file
logwidth:&nbsp;&nbsp;&nbsp;&nbsp; 30&nbsp;&nbsp;&nbsp; # Width of address fields in logfile
retpath:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # Do/Don't use 'return-path' for errors
maxhops:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 30&nbsp;&nbsp;&nbsp; # Used to detect mailing loops
gullible:&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, don't validate 'From' fields
bitnethost:&nbsp;&nbsp; cunyvm.cuny.edu&nbsp;&nbsp;&nbsp; # Relay host for '.bitnet' rewrites
poll:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 10&nbsp;&nbsp; # Seconds between queue polling cycles
scratch:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; i:\MERCURY\Scratch&nbsp;&nbsp;&nbsp; # Where we can write temp files
returnlines:&nbsp; 15&nbsp;&nbsp;&nbsp; # How many lines of failed messages to return
postmaster:&nbsp;&nbsp; admin&nbsp;&nbsp;&nbsp; # NetWare UIC of postmaster
broadcast:&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # Yes, we want broadcast notifications, but
receipts:&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # ... no broadcasts for receipt confirmations
PM_notify:&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # Do/Don't send errors to the postmaster
change_owner: 0&nbsp;&nbsp;&nbsp; # Change message ownership to recipient
auto_tzone:&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # If NZ, obtain timezone information from OS
LogLevel:&nbsp;&nbsp;&nbsp;&nbsp; 15&nbsp;&nbsp;&nbsp; # System message reporting level
LogMax:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 100&nbsp;&nbsp;&nbsp; # Maximum number of system messages to store
RetryPeriod:&nbsp; 15&nbsp;&nbsp;&nbsp; # Period between job retries (minutes)
MaxRetries:&nbsp;&nbsp; 20&nbsp;&nbsp;&nbsp; # Maximum number of times a job can fail
TwoPasses:&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, process submission queue in 2 passes
Autoaddress:&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, auto-generate user addresses based on name
Daily_exit:&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # If NZ, auto-restart each day after maintenance
No_Areply:&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, disable automatic replies system-wide
Alt_Forward:&nbsp; 1&nbsp;&nbsp;&nbsp; # If NZ, allow alternate forwarding specification
Maint_hour:&nbsp;&nbsp; 3&nbsp;&nbsp;&nbsp; # Hour for daily maintenance (24-hour clock)
Maint_min:&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # Minute for daily maintenance
Retry_Mode:&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # If NZ, use progressive backoff for queue retries</P>
<P>[MercuryC]
Poll : 30
ReturnLines : 15
Timeout : 30
ESMTP : 1
POP3_Auth : 0
Log_Verbose : 0</P>
<P>[MercuryE]
Session_logmode : 0
Poll : 5
Timeout : 60
Logfile : log.txt
Log_Verbose : 0
DNS_Timeout : 20
DNS_Retries : 4
Transcripts : 0</P>
<P>[MercuryD]
Timeout : 30
Poll : 60</P>
<P>[MercuryS]
Debug : 1
Timeout : 90
Relay : 0
Strict_Relay : 1
Server_Port : 125
Allow_Illegals : 0
SSL_Mode : 0
ST_Blacklisting : 0
No_VRFY : 0
SMTP_ConnFlags : 0</P>
<P>[MercuryP]
Stack : 32768
Mark_Read : 1
SSL_Mode : 0
Login_Disabled : 0
Session_logmode : 0
Timeout : 60</P>
<P>[MercuryX]
# Cmd_Delay: 10
# Cmd_Wait: 1
# IE4_Dialling: 0
# Use_ETRN: 1
# Clients_only: 1
# Saturday: 1031,1035,2,45,-1,0</P>
<P># [Groups]
# testgroup&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; TESTGRP</P>
<P>[Domains]
helppc.org: helppc.org</P>
<P>**HELPPC:&nbsp; helppc
**HELPPC:&nbsp; helppc.org
**HELPPC:&nbsp; [87.235.215.29] ; if you have a fixed IP address.
[Maiser]
Maiser:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Maiser&nbsp;&nbsp; # 'Username' of mail server account
Helpfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; i:\MERCURY\Mercury\MAISER.HLP&nbsp;&nbsp; # Help sent on failed maiser requests
Lookupfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; i:\MERCURY\Mercury\MAISER.LKP&nbsp;&nbsp; # Format file for the 'lookup' command
Send_dir:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; i:\MERCURY\Mercury\SENDABLE&nbsp;&nbsp; # Directory for the 'send' command
Logfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; i:\MERCURY\Logs\MAISER.LOG&nbsp;&nbsp; # Mail server log file
Notify:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; i:\MERCURY\Mercury\TMP&nbsp;&nbsp; # Dir. for pending 'notify' commands
NoList:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; N&nbsp;&nbsp; # If 'Y', disable the 'list' command
Local_only:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; N&nbsp;&nbsp; # If 'Y', local 'notify' commands only
Admin_Passwords: D:\MERCURY\MERCURY\maiser.pwd&nbsp;&nbsp; # File for mail server administrator passwords</P>
<P>[MercuryH]
Timeout : 30</P>
<P>[MercuryI]
Timeout : 240
Server_Port : 143
Session_logmode : 0
Idle_Timeout : 3600
SSL_Mode : 0
Login_Disabled : 0</P>
<P>[MercuryB]
Timeout : 120
Server_Port : 9080
Idle_Timeout : 1800</P>
<P>[Groups]</P>
<P>[Rewrite]</P>
<P>[Statistics]
StatFlags:&nbsp;&nbsp;&nbsp; 16&nbsp; # Statistical reporting settings
StatFiles:&nbsp;&nbsp;&nbsp; i:\MERCURY\stats.mer&nbsp; # Directory to write stat log files
StatMail:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # Address to send stat log files
STF_Hours:&nbsp;&nbsp;&nbsp; 24&nbsp; # How often to write stat log files
STM_Hours:&nbsp;&nbsp;&nbsp; 2&nbsp; # How often to e-mail stat log files</P>
