[quote user="irelam"]I hope someone else who is running Win7 can help you[/quote]Thanks, I finally found it: Control Panel=>Personalization=>Windows Color=>Advanced Appearance Settings. The OP may wish to play with the parameters here, although I've yet to find any setting that magnifies the tiny font that appears in some Pegasus windows, eg. the one that queries whether there's mail on the server.
Also of use might be the magnifier utility that comes with Win7, and the individual program compatibility settings where there's an option to automatically revert the screen resolution to 640x480 when firing up the program. (That causes horrendous magnification when you've an optimized HD display. If there were a Win7 setting to change that default to a resolution of one's choosing... cool beans.) There are one or two other compatibility settings that may be useful for small font issues. I suspect, unfortunately, that the real issue has to do with the way the font implementation in Pegasus interacts with OS font control. I believe David Harris has commented on this elsewhere. I hope it can be addressed at some some point.
Having said all that, as a long time user, I wish to assert my great appreciation for this program, and my admiration for the service that David Harris has afforded the wired world. -Ron
<p>[quote user="irelam"]I hope someone else who is running Win7 can help you[/quote]Thanks, I finally found it: Control Panel=&gt;Personalization=&gt;Windows Color=&gt;Advanced Appearance Settings.&nbsp; The OP may wish to play with the parameters here, although I've yet to find any setting that magnifies the tiny font that appears in some Pegasus windows, eg. the one that queries whether there's mail on the server.&nbsp; </p><p>Also of use might be the magnifier utility that comes with Win7, and the individual program compatibility settings where there's an option to automatically revert the screen resolution to 640x480 when firing up the program.&nbsp; (That causes horrendous magnification when you've an optimized HD display.&nbsp; If there were a Win7 setting to change that default to a resolution of one's choosing... cool beans.)&nbsp; There are one or two other compatibility settings that may be useful for small font issues.&nbsp; I suspect, unfortunately, that the real issue has to do with the way the font implementation in Pegasus interacts with OS font control.&nbsp; I believe David Harris has commented on this elsewhere.&nbsp; I hope it can be addressed at some some point.&nbsp; </p><p>&nbsp;Having said all that, as a long time user, I wish to assert my great appreciation for this program, and my admiration for the service that David Harris has afforded the wired world.&nbsp; -Ron
