Pmail won't Start
And at first look if there is any *.cnm file having 0 bytes - this one you surely can delete safely! The others *.cnm move somewhere instead of raw deleting - you may want to get them back.
I sent a email from Pegasus 4.52 and it did not go.  When I try to open Pmail I get a dialog that says it appears to be locked by another process.  I hit continue and them get a box that says it has stopped working and has to shut down. Help is appreciated.  I am using Win 7 Ultimate.  TIA
Gene
<P>I sent a email from Pegasus 4.52 and it did not go.  When I try to open Pmail I get a dialog that says it appears to be locked by another process.  I hit continue and them get a box that says it has stopped working and has to shut down. Help is appreciated.  I am using Win 7 Ultimate.  TIA</P> <P mce_keep="true"> </P> <P>Gene</P>
Have you tried the standard method of removing all of the .cnm files from your mailbox to see if the problem is one of the new messages in your inbox?
